Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-30-2007, 01:00 PM   #1
finalcutjoe
finalcutjoe's Avatar
Profile:  2008 30' Classic S/O
dearborn , Michigan
disconnected duct
While winterizing the water pump, I noticed a 2” flexible duct that was unattached on one end, just laying in the ‘plenum’ space
I’m talking about the service space under the access panel in the cedar closet (2008 classic)
I couldn’t see any supply/return connections that it should be hooked to….
Is it possible its supposed to be disconnected- to heat the ‘service’ space?
finalcutjoe is offline   Reply With Quote
Old 11-30-2007, 01:02 PM   #2
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Mine is the same way - I think that it is one of the heat ducts to the "basement".
Pat
pmclemore is offline   Reply With Quote
Old 11-30-2007, 04:02 PM   #3
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
THis is correct
This is correct. It is supposed to heat the tanks.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 11-30-2007, 06:26 PM   #4
finalcutjoe
dearborn , Michigan
thanks Pat
thanks Michelle
Duct work mark silberl Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-30-2007 03:11 PM
Heater Duct Cleaning REDNAX Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-18-2007 08:39 AM
Disconnected Battery while driving Dan S All Argosy Trailers 8 08-07-2007 01:01 PM
Duct to nowhere walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-17-2004 08:16 PM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 06:54 AM
test
