Old 01-16-2006, 06:10 AM   #1
grannyred's Avatar
1959 22' Flying Cloud
Bowden , West Virginia
Digital Thermostat
Has anyone changed to a digital thermostat for their heating system? If so, what brand did you change to. Took my Atwood thermostat to Home Depot yesterday and no one there could tell me if any of their digital thermostats would work in a trailer.
I use my trailer year around so i don't winterize it by draining all the fluids from the lines. Instead I turn the heater on and set the thermostat to the lowest setting which is 50 degrees. Needless to say I am burning thru propane rather quickly on cold evenings when the temperatures are not at or below freezing.
grannyred is offline   Reply With Quote
Old 01-16-2006, 07:09 AM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Might not work
You may have trouble using a digital unit. I am not an HV/AC expert or even amateur but I do know that the standard house furnace uses 24 volts A.C. for control of the system. That is basically the signal from the thermostat to the furnace that tells it when to turn on and off.
There is usually a small relay in the digital thermostat that does this and it is powered separately from the thermostat (which is usually powered bu a couple of AA batteries.
The furnace in a trailer probably only uses 12 volts D.C. to run so that may not be high enough to operate that relay. Besides the trailer operates (at least ours does) on a 2 wire system where the house operates on a 4 wire system to run heat in the standard home.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 01-16-2006, 08:21 AM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Check out this thread:
http://www.airforums.com/forum...ace+thermostat
There is another thread I remember where one forum member purchased a battery powered thermostat and had pictures of the install. I can't remember who it was right off hand.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-16-2006, 08:26 AM   #4
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I stand corrected. This is good info (and a reminder for me to use the search feature more). I think I will replace our thermostat as well!
Old 01-16-2006, 09:25 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Pick up a "Just Right" digital thermostat made by Hunter. WalMart sells these for about $20. I used one to replace the Atwood junk that came on my 2001 Safari. Worked great and if you don't like it, its always returnable.
Here's my thread on the topic.
http://www.airforums.com/forum...tal+thermostat
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-16-2006, 07:48 PM   #6
grannyred's Avatar
Thanks everyone. I purchased a "Just Right" at Lowes this evening. $25. Will install the thermostat tomorrow.
Ken
Old 01-16-2006, 08:45 PM   #7
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
I put in a Hunter Set n Save II, same one I use in the house. 2 AA batteries. Works great, very even heat although 2 degree spread from set temp.
Safari64
Safari64 is offline   Reply With Quote
Old 01-17-2006, 03:46 PM   #8
grannyred's Avatar
Installed the "Just Right" today. Works great. thanks for the suggestion.
Ken
Old 01-18-2006, 08:11 AM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
Yeah, it really made a difference in our Safari. The batteries will last at least a year or more, so its not a big issue that you aren't tied to a transformer.
Jack
Jack Canavera
STL Mo.
AIR #56
Thermostat replacement jcanavera 2001 Safari 7 07-26-2017 08:58 AM
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
Oven Thermostat PeterH-Airstreamer Stoves, Ovens & Microwaves 33 02-20-2003 09:39 AM
a/c theromstat sudden impact Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-09-2002 06:04 PM
Converting the old heater to a thermostat? 61BambiCanada Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-22-2002 06:09 AM
