Old 10-02-2013, 08:56 PM   #1
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
DeLonghi Hot Oil Electric Heater
I have been a fan of the DeLonghi hot oil heaters for some time. They put out the same heat as all the other electric space heaters, 1,500 watts, cost less than $50, no noise and nothing gets red hot.
I ran across another DeLonghi heater that looks like it was just made for our 66 Tradewind. It is smaller than the standard "radiator" type DeLonghi heater, with an output of 1,200 watts, is shorter, 15" vs. 26", wider 18" vs 14" and looks kind of like an Airstream, at least to me.
I say it is made for the Tradewind because if you close the bathroom door and the door to the front living area, you are only heating an area with about 40 sq ft of space. I suspect this heater will be fine down to 32 degrees or even lower. It is more expensive than the larger heater because it has a timer and they don't sell as many. It works well for us if you have hookups and it is not too cold out.
I would also add that it is a more stable heater than the larger "radiator" type heater since it is shorter and is not on wheels.
Dan
ID:	196955   Click image for larger version
Old 10-02-2013, 11:25 PM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I have 2 of those units for my 32.one at each end of the drainpipe. The built in timers are a real nice feature. I cycle them at night and then have them both on an hour before waking up. IMHO they are worth the extra few dollars. Both units are now 5 years old and still work like a charm.
doorgunner is offline   Reply With Quote
Old 10-03-2013, 01:19 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, same exact heater that I have been using for years now.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-03-2013, 04:44 AM   #4
2005 28' Safari
saline , Michigan
Yes, I use that one in my 28' Safari rear bed. If you run a small quiet fan over it , it will keep the whole trailer warm.
Kosm1o is offline   Reply With Quote
