Old 04-28-2006, 07:30 AM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Dam furnace lock out!
Well I have the original Suburban furnace in my 1979 Airstream. Was having problems with the furnace getting into lockout mode when I let it run all night where I would find it the next day running with the blower on but with no heat.
Took the whole thing of of the trailer, blew everything out. Sail switch checked out just find and was freely swinging. The rest of the furnace seems to be in good shape. The exchanger seems to be solid. Replaced ignitor/flame sensor. Put back together. Ran it overnight the first night on battery only and it worked perfectly. I was estactic.
I let it run again last night overnight only to find it back in lockout mode this morning. Don't know what else to try. I am going to get my tanks filled up with propane tonight as I don't know how much is left in them.
Frustrated!
Steve
wacnstac is offline   Reply With Quote
Old 04-28-2006, 03:43 PM   #2
Images: 43
Well this time it turns out it may be empty tanks. One was totally empty and one is very near empty. Hopefully this can cause the syptoms I saw as the furnace did run flawlessly one night after I put the new ignitor in. Went to take to tanks to get refilled and even though they have the new valves, they wouldn't refill them because now they have to be RECERTIFIED! If it's not one thing, it's three.
Old 04-28-2006, 08:36 PM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
One other thing you might check is to make sure your regulator is set for the proper pressure. That will cause refrigerators to not run properly, and I think it is true with the furnace as well. If you have your manual, check to see what it requires. I think it is 11-12 inches of water.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 05-03-2006, 06:55 AM   #4
Images: 43
Nope, spoke too soon. With two full tanks the thing was still in lockout when I checked it this morning after a night's run. Frustrating to say the least!
Old 05-03-2006, 10:49 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Steve,
The fault could be with your main regulator at the tanks. It should be putting out 11" water guage pressure at 50% draw (a monometer will measure this). Also check the gas valve on the firnace. It might be mis-adjusted or defective .
Old 05-03-2006, 01:21 PM   #6
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Propane Leak Detector?
Would value Lew's opinion on this as well.. It might be possible there is still small propane leak, or propane leak detector malfunctioning, as it is intended to shut off flow of propane after detecting in the coach, and then resetting itself when problem clears. Does stove continue to work well when furnace shuts down?
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 05-03-2006, 01:46 PM   #7
Did you fit a new circuit board? http://www.airforums.com/forum...bug-21981.html
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-03-2006, 05:11 PM   #8
lewster's Avatar
John McG
A definite possibility and a good way to check out the LP system when the furnace cuts out. If you DO have an igniter board, then it might have a fault in the circuitry that could be causing the problem.
Old 05-03-2006, 07:58 PM   #9
Images: 43
The stove works fine after I find the furnace blowing cold air. I didn't know these things had propane detectors in them though.
Old 05-03-2006, 08:11 PM   #10
1988 25' Excella
Images: 13
May not have been required in '79, but look for small panel with light and switch near floor and in kitchen area or near furnace or steps. By late 1980's that unit had to be functional and not snifffing propane in order for propane to flow past it into appliances... It is one of two parasitic battery killers if not switched off when you leave unit...
The other is mystic defrost switch on top surface of many Dometic Refrigerators.. Doesn't do much, but will be current drain if left on...
John McG
p.s. Liked the idea of leak testing with hose from inside wheel wells.. Wheel well liners hardly very structural, and water from tires could easily fly past seams. Doesn't seem as likely when trailer parked, however, but could be...
Condoluminum
Old 05-04-2006, 06:07 AM   #11
Images: 11
Send a message via AIM to ronmcor
I had exactly the same symptons you do on my 88 Excella. Turns out the previous owner had the wrong ignitor in the furnace. It was too short and did not always re-light the furnace. Long shot maybe, but it did happen to me.
ronmcor is offline   Reply With Quote
Old 05-04-2006, 06:48 AM   #12
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Question: How are you resetting the furnace after it "locks out"? I am finding this to be a curious problem myself...
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 05-04-2006, 07:07 AM   #13
Images: 43
The ignitor is a brand new one and an exact replacement for this furnace (after 2 wrong ones). I reset the furnace after lockout by simply turning the thermostat to off and then back on. As for the wheel well leak, I am not spraying a hose there. The water is coming from somewhere else and you can see the moisture along the C channel at the front of the wheel well and no, the trailer was not being towed in the rain.
Steve
Old 05-04-2006, 09:36 PM   #14
Images: 43
Another symtom I have noticed and am not sure if it is significant is that occasionally after the thermostat is satisfied and the blower shuts off, the blower will then cycle on and off several times. I assume this is because something is still detecting heat in the chamber which needs to be blown out but maybe it is a sign of something more serious. Would this be a problem with the main board, or is there another switch involved?
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
