Old 12-23-2014, 07:02 AM   #15
65will
65will's Avatar
1969 25' Tradewind
Greenwich , New York
is the vent hole the right place?
Hello Tentmaker.
The placement of your A/C is imporant for ballance, and proper weight distubuation. This will affect toung weight and weight over axle. You do need your inner skin on to do your install. Airstream web page can give you the proper placement for the unit. Also in my opinion you should put braces from rib to rib for support of the unit. Are you putting the drain kit in? with your skins out is a great time to run the drain tube. Good Luck with your install.
65will is offline   Reply With Quote
Old 01-01-2015, 09:11 PM   #16
1967 22' Safari
Auburn , Alabama
65will and cwf. Thank you for your reply. I'm not sure why, but I did not get notified when you posted. If I had read your suggestions I would not have removed my middle vent today... Bummer.
Now I have the middle of the 3 vent curbs removed and I was planning on putting my AC in this weekend. After reading this I changed my mind. Makes sense - I can't compress the seal without having the inner skins in.
I've attached a pic of another situation that I have. The PO had installed really nice flexible solar panels on either side of the vents. The problem is the compression gasket will overlap the panel preventing me from an ideal seal (gasket to aluminum).
Do you think slightly overlapping this gasket and sealing with trempro will suffice? If not I will have to remove both panels.
I'm attaching a pic. Click image for larger version
Name:	ImageUploadedByAirstream Forums1420168085.936478.jpg
Thanks guys!!!
Tentmaker is offline   Reply With Quote
Old 01-01-2015, 09:37 PM   #17
ottawa (greely) , Ontario
You can't mount anything on top of the solar panel if you cover just a few cells it's output will be extremely low , and your better to mount a.c directly gasket to aluminum .
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Cutting perfect hole-furnace exhaust in skin Lothlorian Ribs, Skins & Rivets 16 10-08-2013 11:03 PM
Cutting hole for 75 Argosy AC DearArgosy Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-19-2012 05:32 PM
New black tank, cutting a new hole? akmntman Waste Systems, Tanks & Totes 8 07-24-2010 12:19 AM
cutting 14 x 14 hole in roof mwillis1970 Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-04-2005 10:36 AM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 12:57 PM
