Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-08-2008, 07:26 PM   #1
Gregg S's Avatar
Profile:  2002 25' Safari
quincy , Massachusetts
Crack in A/C Shroud
I have an 02 Safari with a Dometic A/C unit and just noticed a 2" crack starting from the attachment screw hole going up the cover. Is this cover ABS Plastic or Fibergalss. I know how to fix fiberglass but if it is ABS I haven't a clue. Duct Tape?
Gregg S is offline   Reply With Quote
Old 05-08-2008, 07:29 PM   #2
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I used J B Weld and it has held up fine over the last 8 months.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
davidz71 is online now   Reply With Quote
Old 05-08-2008, 08:40 PM   #3
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Mine cracked last year. I bit the bullet and bought a replacement this spring. I figured once it started the UV had probably gotten to it, and it probably will fail somewhere else and at an inopportune time.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
Old 05-08-2008, 08:42 PM   #4
jbond's Avatar
Profile:  Shalimar , Florida
Images: 13
ABS "Permanent" Repair
Posted from the Apache Forums
The best ABS crack repair you can do is with MEK (MethylEthylKetone) and ABS powder or chips. MEK can be found at most hardware stores, and it does a great job melting ABS (given time). ABS could probably be found at a hardware store in the PVC area. If someone finds a good source for white ABS, please let me know. You'll have to grind it up somehow (file or saw, etc.). The best repair method I've seen was described by Gary Burch. Use a small metal or glass jar with a lid. Mix about equal parts MEK and ABS powder or chips. If using chips, the smaller they are, the better, as they take time to melt. Cover and let sit a few minutes, then uncover and stir. Repeat for the next 30 minutes or so until all the chips are melted into a nice thick toxic goo. I've only tried ABS chips, but powder should melt a lot faster than chips. Anyways, this goo can then be spread over the cracks. Work quickly, as it dries fast. Ideally you'd rough-up the ABS surrounding the crack and carefully clean it with ABS/PVC cleaning solvent prior to applying the goo. Be careful with the cleaner as it can drip down the side and remove the white color of the ABS. You can also use fiberglass strips to cover larger holes first before applying the goo. Multiple thin coats are better than one thick coat.
This type of repair will outlast any repair made with fiberglass material only. I've had great success with this method. It can even be sanded smooth and painted. Oh yeah - Apache Sales and others sell pre-mixed goo by the can (for around $12.00). Happy patching! -
Herb
_________________
Wally# 1861
1ST VP VAC
Past Prez of Unit 029 in P'cola
63 Globetrotter Patty
63 Suburban Andy
63 Overlander Tex
62 Overlander Doc
jbond is offline   Reply With Quote
Old 05-09-2008, 09:17 PM   #5
Gregg S's Avatar
Are the shrouds univeral or and airstream only part. Can you get them from any RV dealer or just AS supliers?
Old 05-09-2008, 10:05 PM   #6
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
They are available from any RV supply store. I just googled "rv air conditioner shroud", and got an immediate hit:Duo-Therm RV Air Conditioner Shrouds for Sale
"I'd rather wake up in the middle of nowhere, than any city" Steve McQueen
AIR#2611
overlander63 is online now   Reply With Quote
Old 05-10-2008, 08:06 AM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
They aren't cheap though so be prepared to spend at least $100+. The Duo-Therm replacement shrouds made for the Penguin's comes with new gasket material. The gasket is part of the air channeling system that properly directs the air flow through the shroud. It compresses over time and a shroud replacement without a new gasket may not seal tightly thus causing poor air flow over the coils.
I bought my replacement from the local Airstream dealer. It didn't cost me any more than any site I could find on the Internet, especially once you add shipping charges.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
Old 05-10-2008, 11:41 AM   #8
Commercial Vendor
Profile:  Corona , California
Three things attack the AC covers.
UV from the sun.
And, believe it or not, lack of proper running gear balance.
Also lack of enough fasteners allows the cover to flutter when going down the road.
Adding "fender washers" usually takes care of the vibration problems.
Painting the shroud stops the UV problems.
But hey, if you didn't take the time to have some things repaired on your Airstream, you would have to do more camping.
That's great too, except for the fuel prices today.
The oil companies are causing all kinds of prices to rise, even at grocery stores.
I hope they soon back off, so as to not cause a total economical breakdown in our country.
All of our vendors, without exception, have gotten on the band wagon, and have already raised prices from a little, and some to hell and back.
We will hold our price structures as long as we can.
Ah yes, oil companies say they are not the problem, but they all report huge, unheard of profits.
Makes for a good discussion, as to "who" really runs our country, politicians or greedy oil companies?
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Pingbacks are On
Does Your Crack Need Cured...? Ganglin Off Topic Forum 8 05-13-2007 10:32 AM
Exterior crack above door Teacher3rd Ribs, Skins & Rivets 24 02-04-2007 12:48 AM
frame crack jimnsue Repairing/Replacing Floor &/or Frame 7 10-09-2006 10:25 AM
Crack(s) in interior ceiling mcgivern General Interior Topics 8 10-13-2005 09:44 AM
Frame crack Creampuff 1966 - 1968 Safari 4 11-03-2004 01:53 PM
SEO by vBSEO 3.1.0
