Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 08-28-2007, 12:02 AM   #1
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Copper pipe bending and replacement of old NT30MA with new NT30SP
Just bought a NT30SP to replace my old NT30MA. Everything line up except for the gas line which has moved from the top of the furnace to the bottom and the duct work which has moved up approx 3/4". The picture below shows where the gas line and duct work is currently:
I plan to run a piece of flexible gas line from the compression fitting up top, around the duct work to the front and then down to the new gas input. The problem is that the old duct work has to come up about 3/4" and the copper gas line above it needs to come up by the same amount. I believe I can get the play in the duct work to bring it up, but I'm not sure what will happen if I try to bend the existing copper pipe up and backwards a bit to go over the raised duct work.
Any tips on how to bend this copper pipe up enough for clearance without kinking or breaking it?
wacnstac is offline   Reply With Quote
Old 08-28-2007, 12:24 AM   #2
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If I understand you correctly, you need to raise the fitting less than an inch, right? You are straightening the pipe rather than bending it, and only a slight amount. I would anticipate no problems with holding it at the beginning of the bend, and lifting the fitting.
Vaughan
Old 08-28-2007, 12:25 AM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Get a tubing bender or you will kink the tube. Don't bother with the spring slip-on types as they don't work. You will need one the proper size......the O/D of the tubing to properly support it while you bend it. Even a little movement will most likely kink it.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 08-28-2007, 12:43 AM   #4
vswingfield
1967 24' Tradewind
Images: 32
Sound advice for bending. The spring types really don’t work, and you can’t use them with flares and fittings on the line anyway. I have never had problems making slight adjustments to copper pipe, especially when straightening, to a variety of sizes. Given the generous radius of your bend (RE comment from Lewster about tube benders) you probably will be Ok with a little hand adjustment. Just don’t try to make it completely straight. Anything more than about an inch would probably be better served by cutting off the bend and using a longer flex line. Also, given what looks like very limited overhead clearance in your photo, I’m not sure how a bender would work for you to straighten the tube. However, you should just own a tube bender and a flaring tool. I personally have a double flaring tool, so I can flare brake lines.
Best of luck,
Vaughan
Old 08-28-2007, 12:44 AM   #5
klattu
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 854
U Tube
Yes on the tubing bender.
I found a heavy plastic one that can be taken apart, so it can be held on pipe as bends are taken back out.
Pipe is supported down deep in a U shaped grove.
Then you can use same bender to raise your radius point, and make it a smaller radius to give the height needed.
klattu is offline   Reply With Quote
Old 08-28-2007, 08:25 AM   #6
Spiffy Gem
BoiseState
Spiffy Gem's Avatar
Profile:  1966 22' Safari
All my life in , Idaho
Images: 41
If faced with the same challenge, I would cut that copper just below the flooring, install a brass fitting that will sandwich the floor solidly, and come up from the floor with the new steel reinforced rubber stuff available today.
Spiffy Gem is offline   Reply With Quote
Old 08-28-2007, 08:40 AM   #7
wacnstac
Images: 41
Spiffy please explain. How would you cut the pipe below the floor line and still be able to work on it? What kind of brass fitting are you talking about? Would I need to put a new flare on the pipe? I'm not sure I'm capable of doing this especially with old copper.
Old 08-28-2007, 09:50 AM   #8
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Wacnstac,
When you slide the furnace back in - how much space do you have from the furnace ducts to the duct line you show in your photo... any?
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 08-28-2007, 10:03 AM   #9
Spiffy Gem
BoiseState
Spiffy Gem's Avatar
Images: 41
WacnStac,
Yes, you will need to flare the old copper: I don’t know why that couldn’t be done to the old copper. If you can’t do this to the old copper, then I would think it needs replaced! Truth is you may very well be doing that before this job is done anyway.
If you have never used a flare tool, they are cheap. Get a piece of copper from the hardware store to practice on, that way you won’t hate meJ.
Copper Pipe:
You will want to cut the copper pipe just above the floor. After doing that, go under the coach and unfasten the clamps that secure the pipe so you can pull it down/out of the floor.
Belly pan:
You will have to gain access from the bottom to install the copper fitting and make the connection to the newly flared copper pipe and related fitting, so you will have to get through the belly pan. To do this, I cut a 6”x6” square, using a dremel. That is big enough for me to get both hands in with a wrench.
When you are done, you can use a 10”X10” piece of aluminum sheeting, drill a ¾” hole (or use a knock-out) in the center, to patch this opening afterward. I cut this sheeting in half after I drill the hole, place the back half, rivet it in place, then install the front half with some overlap over the back half.
Brass Floor fitting:
I don’t have a picture of the brass fitting that goes through the floor (I will have to get that for you tonight), but basically it is a threaded critter that is a bolt on the outside with a nut and lock washer that you can securely tighten to the floor, yet connect a flared fitting on the two ends.
I know this sounds like a lot of work, but it really isn’t. I did this two nights ago, and installed the copper line under the TT in less than an hour. You gain an issue-free securely installed propane line through the floor, and added flexibility to modify or replace the line inside. You can then make whatever interior modifications you wish, without issues.
Old 08-28-2007, 10:31 AM   #10
lewster
Commercial Vendor
lewster's Avatar
Best of luck,
Vaughan
Hey Vaughan.......
Just so you know....the current RVIA specs call for double flares on LP lines also .
AIR # 10325
Old 08-28-2007, 10:38 AM   #11
wacnstac
Images: 41
I think I'll try bending the old pipe ever so slightly first If I put some 4" duct offsets in between the big square duct that goes right to the furnace now and the furnace itself that will buy me some wiggle room. I don't see me being able to put a new pipe in with double flares.
Old 08-28-2007, 11:34 AM   #12
lewster
Commercial Vendor
lewster's Avatar
Gas-flex is fine.......just be sure that you secure it well so it doesn't move around when you are moving down the road. The ends of the gas-flex should mate properly right up to the flare in your photo. Be sure to test for leaks with a soapy water solution before attempting ignition.
PS: even though it is a new furnace, I would bench test it prior to installing it. I do this with every new appliance I install now after I actually had a defective water heater right out of the box. A little time spent here can save you a major headache!
AIR # 10325
Old 08-28-2007, 11:43 AM   #13
vswingfield
1967 24' Tradewind
Images: 32
Hey Vaughan.......
Hi Lew,
That's right. I guess there's just something about copper pipes that gets me thinkin water. Might be all the frozen pipes I had to fix in the 67 Trade Wind.
Vaughan
Old 08-28-2007, 11:59 AM   #14
wacnstac
Images: 41
The gas flex should be fine especially considering this unit is being used basically as a Park unit and is not pulled anywhere. How would you bench test it? Just hook up 12 volt + and - and put 12+ on the thermostat pin? I do have a spare propane tank and regulator lying around. Actually after my old furnace blowing up on me in the driveway while bench testing it see: http://www.airforums.com/forums/f427...0ma-35151.html
What is this I see about running the fan without gas first? How does one accomplish this on these new units? Is it done by turning the switch to off on the control board and actuating via the thermostat? Or do you turn the switch on the board to on and run the furnace with no gas connected?
A/C replacement photos Zeppelinium Furnaces, Heaters, Fireplaces & Air Conditioning 15 08-22-2007 08:09 AM
Question on partial floor replacement soldiermedic Repairing/Replacing Floor &/or Frame 43 11-19-2006 05:29 PM
Dissimilar Metal Corrosion JIM Bowers Exterior Restoration Forum 1 01-26-2006 05:15 PM
Need help removing plywood floor section brentleew Repairing/Replacing Floor &/or Frame 49 02-16-2004 05:46 AM
Floor Replacement in 63 Safari srgntpepper Repairing/Replacing Floor &/or Frame 2 08-07-2003 07:20 PM
test
