Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-17-2006, 10:58 PM   #1
Profile:  1969 27' Overlander
Auburn , Washington
copper pipe/ac
O.K.
About half way done gutting the inside of our 69 overlander, not counting the bathroom which looks like a frightening task, but will cross that bridge another day. So here's tonites question- What should I do about the copper pipe coming down from the ac unit? Its pretty much right there in the way in almost the middle of the trailer. And whats in it? Gas,water, freon? And where does it lead too after it goes through the floor. These are things that will keep me awake tonite pondering. Regards to all, Mark
mark silberl is offline   Reply With Quote
Old 11-17-2006, 11:06 PM   #2
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Drain Line
Originally Posted by mark silberl
O.K.
I think that is the drain from the drain pan on the AC. Leave it in place if you are going to have an AC.
Thanks Jim
Air # 174
Jim Clark is offline   Reply With Quote
Old 11-18-2006, 01:42 AM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
It does sound like the drain from the AC pan and it most likely sticks out the bottom of the trailer so that it can drain onto the ground. The way you make it sound it is in the middle of the room. If it is the drain line, there is no reason it has to be copper. I would route the drain line between the skins and out the trailer if possible.
BTW, a picture would be helpful.
Richard
Charter Member Four Corners Unit
Old 11-18-2006, 06:39 AM   #4
Jim Clark's Avatar
If you do change the material of the drain line consider the chaffe to the line which can result from the vibration of the trailer as you go down the road. If a leak developes the condensate from the AC will end up inside the skin and in the insulation.
Thanks Jim
Air # 174
Old 11-18-2006, 06:15 PM   #5
Auburn , Washington
upon further inspection
Yes, it does seem to be the drain. It will have to go for now though as its right in the way. Rerouting it seems like a good idea.Tried to attach a photo, but my computer skills are almost as limited as my remodeling abilities. Thanks for the help, Mark
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 01:03 PM
LP Wierdness / Where to buy copper LP pipe and fittings? nickglase LP Gas, Piping, Tanks & Regulators 19 03-11-2006 04:43 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 02:04 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 08:14 PM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 07:04 AM
