Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-31-2007, 06:38 AM   #1
RedSHED
many cheeses are edible
RedSHED's Avatar
Profile:  1985 31' Excella
Columbus , Indiana
Cool air, weak fan?
We have an '85 Excella, 31ft. Our furnace is under the oven which is right next to the door in the "living room" area. The fan is a bit noisy, it squeals a little, but our real issue is we get only slightly warm air coming out of the vent that is only an inch or two from the furnace in the living area. The air from the vent in the rear bedroom area is only slightly warmer but not great. The outside furnace vent blows hot air.
DH suspects it might be the fan is too weak to force the air through, which would be consistent with the fan noise. He took off a "faceplate" and felt truly hot air coming out.
Any ideas or suggestions? Thanks!
Mrs RedSHED
RedSHED is offline   Reply With Quote
Old 03-31-2007, 08:17 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
If the fan is too weak, I would think the air coming out of the vent that is only an inch or two from the furnace in the living room would be very warm.
How is the relative force of the air?
You might have a burner log issue where all the gas is not being burned. Do you smell any propane at the outside furnace vent?
Tom
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Cool lites Action Link Archive 0 09-13-2002 11:24 AM
Fan Tastic Fans Gordon Watt Roof Vents, Skylights & Fans 2 06-17-2002 06:39 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
