Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-16-2004, 08:12 PM   #1
steve sands
Profile:
Question combo ac and heater replacement?
Hey guys, I was wondering if they make a combination a/c and heater unit (all electric) to replace the a/c unit on top of my '72 globetrotter? Has anyone ever seen anything like that? Any help is appreciated.
steve sands is offline   Reply With Quote
Old 03-16-2004, 08:20 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Steve,
Dometic makes an AC/heat pump but it only works down to 40 degrees F. Then you heed a heat strip or a furnace.
The biggest drawback will be the lack of tank heat. The furnace blows hot air around the weather and holding tanks. Without the heat they will freeze if you are camping in freezing weather.
It all depends on when and what the weather is when you camp to say if it is enough to have a heat pump only.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-16-2004, 08:45 PM   #3
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 161
Heat Strips in A/C's
Steve Sands - First of all, welcome to the Forum!
Most of the recent conventional A/C's installed also have a resistive heat strip element.
In my opinion, they are mostly worthless, however, with time, it will do some good. I ran a test on mine, the heat strip raised the exiting air by about 10 degrees F. It would take a LONG time for the heat strip alone to warm a cold RV.
But it is better than nothing.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 03-16-2004, 09:26 PM   #4
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
The Dometic heat pump works well and is a good feature. You do need a furnace to keep your feet warm on occasion and to keep your plumbing from freezing while camping when it's in the twenties.
Tinsel Loaf is offline   Reply With Quote
test
