Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-06-2008, 09:26 PM   #1
bertro
Profile:  1971 23' Safari
Groveport , Ohio
Coleman TSR Mach 3 Drain tube
Do I even have a drain tube on my 71 safari? I see the condensation draining down the curbside skin all of the time. I have searched about my situation and mabey the PO replaced my A/C but it sure looks original. Thanks Robert
bertro is offline   Reply With Quote
Old 06-06-2008, 09:29 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
The drain tube on my 75 TW is located just in front of the street side wheels.
Richard
Charter Member Four Corners Unit
Old 06-06-2008, 11:38 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Airstream used Armstrong AC's up to and including 1979.
Someone replaced the original AC with the Coleman. A drain pan was supposed to be used with the Colemans, which in turn had a drain tube hook to it.
The drain tube was built into the trailer shell at time of manufacture.
If you do not have the drain pan, you will have to live with what you have since that pan is no longer available.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-07-2008, 11:57 AM   #4
bertro
Groveport , Ohio
Thankyou, I can live with it untill it breaks down. I do need a shroud but it seems the cost of a shroud that may not fit a new unit in the future is senseless. Thanks again Robert
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 37 09-15-2008 08:03 PM
drain tube for ac ?? PeteL Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-26-2008 10:26 AM
Coleman Mach III gasket bkahler Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-13-2007 06:11 PM
Coleman Fluorescent Tube Cover bevman Lights - Interior & Exterior 2 03-26-2007 10:18 PM
Generator Size for 13,500BTU Coleman Mach 3??? dscluchfc Generators & Solar Power 23 05-24-2005 08:34 AM
test
