Old 06-04-2009, 06:40 PM   #1
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Coleman Super Mach Model 6798 leaking inside
I have a Model 6798 in my 1990 29' Excella that has a leak in the pan next to the drain outlet. The drain is clear, I removed the hose and blew it out from the top and bottom. It does drain out the hose, in fact most of the condensation goes out that way.
To me, it looks like it is rusting out or just crumbling. The PO had put so sort of putty around it which looks like it worked for a long time.
I have cleaned it off and you can see it is really in bad shape.
I really do not want to replace the pan because it looks like to me it would require getting at this from the roof. The seals are really good and no leaks from the top and I do not want to start any new ones.
Does anyone have a better solution to patch this? My Georgia upbringing tells me to apply a liberal amount of duct tape and cover it up, but I would like something a little more permanent.
While I've got everything down, I also want to replace what ever is on the pan in pic 4. It is soaked and nasty and I think it will smell. Anybody know what that is?
It is great having help. I poured thru the forums looking for a similar problem. Did not find one, but did see how to get things down so I could find the problem. Thanks for the help.
Joe
ID:	81656   Click image for larger version
ID:	81658   Click image for larger version
AirHeadsRus is offline   Reply With Quote
Old 06-04-2009, 07:44 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Someone screwed-up the pan install; I don't believe a pan is available anymore, or the AC that used to fit it, for that matter.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-04-2009, 07:54 PM   #3
Rivet Idiot
1999 34' Excella
What can seal it?
Got any idea what can seal it? It is plastic on the outer part.
I would hate to have to go to the junk yard or buy a new one, but I nay have to if they don't sell the part. I'll do the duct tape before I put a new one in!
Old 06-04-2009, 08:10 PM   #4
Mike Leary's Avatar
Images: 11
Nothing will help if you've got a cracked pan. No junk yard, no new one available. I had the same thing happen on one of mine. Go Dometic or continue to leak.
Old 06-05-2009, 12:54 PM   #5
Rivet Idiot
1999 34' Excella
Think I have it fixed
I have gotten it stopped. Air has been running 4 hours and no drips so far!
This is what I did. I took a small wire brush and cleaned all the goop from around the crack and chipped of areas. Then I took the Perma Oxy Epoxy and applied it all over the area where it had leaked and extended it out a couple of inches. This I let cure for about an hour. It said it would set in 5 mins, but I gave it a little more time. I found some old liquid nails that I had and really gooped it on heavy, probably over kill. Not very pretty but you can not see it unless you drop the inside cover. It is also a little flexible so maybe bouncing down the road will not jar it loose.
If it stays and holds, I do not have to buy a new AC.
Joe
ID:	81694   Click image for larger version
ID:	81696   Click image for larger version
Generator Size for 13,500BTU Coleman Mach 3??? dscluchfc Generators & Solar Power 26 07-28-2010 06:07 PM
Any one tried a Coleman Mach 3 P.S. (Power saver) ronstory Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-06-2009 02:07 PM
Coleman TSR Mach 3 Drain tube bertro Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2008 10:57 AM
86 coleman AC is leaking water inside 85Sovereign Furnaces, Heaters, Fireplaces & Air Conditioning 10 08-26-2007 05:44 PM
Coleman Mach III gasket bkahler Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-13-2007 05:11 PM
