Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-11-2007, 12:42 PM   #1
RedSHED
many cheeses are edible
RedSHED's Avatar
Profile:  1985 31' Excella
Columbus , Indiana
Coleman heat strip
We haven't used the heat strip on the Coleman a/c unit in our 85 Excella which we've owned for 1 year. Nor have we ever used a heat strip. A couple other threads indicated that heat strips weren't really good at warming the camper only good enough to take off the chill. However, if we do decide to try it are there any special instructions we need? I've cleaned the filters. Do we just set it to heat then turn it on?
Mrs. RedSHED
RedSHED is offline   Reply With Quote
Old 04-11-2007, 01:16 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
Mrs. RedSHED
That's about it. You will notice a burning dust smell for a while, this is normal, especially on a strip that hasn't been used in a long time.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 04-11-2007, 01:20 PM   #3
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Sounds like we have the same unit, Twist the temp switch to the warmer setting then the selector switch to low heat. The blower will start and heat will take only a few minutes. Works just fine. If you don't get heat within a few minutes you may have a problem. I would not know what that would be as I've not been there yet. Just make sure you have a lotta juice coming into the shore power. DG
The 2 worst things that can happen to an old aviator:
(1) One day you will walk out to your aircraft,
knowing that it will be your last flight.
(2) One day you will walk out to your aircraft,
not knowing it will be your last flight.
Proud Appellation American
doorgunner is offline   Reply With Quote
Old 04-11-2007, 01:25 PM   #4
Alumatube
Alumatube's Avatar
Profile:  Jefferson , Arkansas
Please, if you have not tried turning yours on yet, check the integrity of the coil first and do not stand with your face in the path of the airflow!
We figured out how to turn ours on, and it blew firey sparks in both our faces! VERY startling, and could have been very ugly!! Turns out the coil was trashed and we have searched and searched to find a replacement with no luck. Anyone know where to find one? I think it is a Coleman Mach 2 or 3 unit.
And yes, from what we understand, it is to knock the chill out of the air, not to heat your whole camper. That is the furnace's job.
Good luck!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is online now   Reply With Quote
Old 04-11-2007, 01:30 PM   #5
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
How true Aluma- Stand clear of the vents first time you turn it on, lotsa dust came outa mine, geez how funny, forgot that part. No spare parts here, sorry. DG
Thermostat- heat strip John Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-12-2002 05:16 PM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 02:55 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 03:38 PM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:25 PM
