Old 07-29-2013, 05:46 PM   #1
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Coleman drain pan
Does anyone know if there is drain pan available for a Coleman AC. Looking to replace the AC on our 1980 Caravelle. The current AC is a Coleman and it drains down the out side so I am guessing there is not one currently on it. Or do I need to go to a Dometic DuoTherm if I want it to drain down the drain tube?
thehandyman is offline   Reply With Quote
Old 07-29-2013, 06:22 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
You might try searching for AC Drain and A/C drain or "drain pan" using search tab above in blue bar.. There were several threads a couple years ago about drain pans and drain tubes and various options for different brand A/C's.. I am not sure anyone makes new drain pans, but some might be repairable, and I believe also 1 brand uses a "slinger" to disperse condensate without a drain tube...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 08-01-2013, 07:38 AM   #3
1980 24' Caravelle
brisk air drain cups
Has anyone tried using the Dometic drain cups that screw onto the bottom of the upper unit on a Coleman Mach 3 13,500 BTU. Thought I read some where that it would work with a little adjustment.
Old 08-01-2013, 08:06 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Dometic part # 3107688.016
They WILL work with any A/C unit when properly installed. You will need an internal drain hose to keep the condensate from draining onto your roof.
Old 08-02-2013, 05:55 AM   #5
1980 24' Caravelle
drain
Working on my 1980 AS Caravelle should be one already in it. Can see a black tube where the ac is now. I have blown air up the drain line that exits in front of the curbside aand can hear it coming out in the ceiling around ac.
Old 03-20-2014, 10:53 AM   #6
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I like the idea. I should have found this before I reinstalled the walls. If this is possible to use the Dometic drain cups on the older Coleman I might try to do this before I get the restoration completed. I did not look for a drain tube though. A thought would be to run a new drain tube a few inches away from the AC to the vent stack pipe. It would just require a hole in the pipe and a little sealer around that. Has anybody done this? If it would work the overflow would flow down into the black tank. Would this work?
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 03-21-2014, 06:54 AM   #7
1980 24' Caravelle
The cups work on the new Coleman I installed. You will need to double up the gasket to make them work. On mine the cups stuck out a little from the AC base maybe 3/8 of inch. So I made covers to keep leaves and such from getting inside and plugging up the drain line. No more draining down the side comes out the drain tube like a champ. Draining in to you tank will just fill it up faster. Here where I live with the high humidity the AC will produce over 1 gallon of water in 8 hours.
Old 03-21-2014, 07:00 AM   #8
lewster's Avatar
If you are using a new RVP-Coleman A/C unit, they can be ordered with an internal condensate pump that gets directly connected to your internal drain line. This eliminates any external pan or aux. drain kit.
