Old 08-31-2010, 07:14 AM   #1
Argosy man's Avatar
1973 Argosy 22
Carleton , Michigan
Coleman Delta TX Air Conditioner
This a question for people that know more about how an Air conditioner works than I do (Everybody)
This Air Conditioner is installed on my Argosy travel trailer and it works perfectly. The compressor cycles nicely and it blows extremely cold.
The Question I have is about how the thermostat works. The coldest the air conditioner will get the trailer; with the thermostat set to the lowest is about 70 degrees and then it cycles off the compressor. I would like it to get down to about 65 for when there is a lot of traffic in and out the door. Is it cycling out to keep from freezing up? Is there an adjustment or a change I can make so I can hang meat in my trailer?
The unit is working so well that if there is no way to get it to adjust it colder, I will live with it.
Thank You for any information.
Argosy man is online now   Reply With Quote
Old 08-31-2010, 08:08 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
If it works that well...you may want to leave it alone.
If you must...replace the thermostat.
It cycles via return air temp.
Freezing is an indication of "low on freon".
Suggestion: clean the small filter daily.
kennethowens is offline   Reply With Quote
Replacing Coleman Delta TX 13500btu A/C tr674 Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-23-2014 08:50 PM
Replacement shroud for Coleman Delta TX a/c blackbird Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-03-2013 06:55 AM
Coleman Air Conditioner gunner Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-26-2009 08:40 AM
Old Coleman air conditioner Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-31-2009 06:05 PM
Coleman Delta TX - Repair? Ganglin Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-15-2007 04:06 AM
