Old 06-20-2016, 10:42 PM   #1
hippiechick's Avatar
1966 24' Tradewind
versailles , Kentucky
Coleman delivered but damaged
Received our new Coleman a/c. Box was fine but interior crate was damaged. Bottom pan was bent and compressor is subsequently tilted. Screws holding unit to wooden crate bent and difficult to remove. Contacted vendor who has been very responsive. They said the damage was correctable and if we would do it they would discount the price by 10%. The warranty will remain as new. Any thoughts on this? I have to admit I was expecting a bit more discount.
hippiechick is offline   Reply With Quote
Old 06-20-2016, 10:44 PM   #2
1966 24' Tradewind
Another pic
Old 06-20-2016, 10:47 PM   #3
1966 24' Tradewind
Can only post one pic per post
Old 06-20-2016, 10:49 PM   #4
1966 24' Tradewind
Last one
Old 06-20-2016, 10:52 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
That damage should be no problem to correct and re-align the base pan and thus the compressor. Just be sure to stay away from the copper lines to avoid bending/breaking them and causing a refrigerant leak.
It would be most beneficial in your case to bench test the unit before installation in your trailer. This is fairly easy is you have a 12VDC battery and 10AWG or 12AWG extension cord. Place the unit on a couple of saw horses (trying to stay off of the bottom foam gasket) with the exhaust port at the bottom of the unit unrestricted.
Connect it as if it was in your trailer with the DC cable as marked and the 120VAC wired into the upper control box. Turn it on (you don't need the shroud on for this test) and let it run for 10-15 minutes. Check the air temperature at the exhaust as compared to the air temperature ate intake; it should be 18-22F difference.
If you get that reading, it should be good to go for installation!
Old 06-21-2016, 04:27 AM   #6
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
IMHO, the 10% does not seem reasonable. You paid for a new unbroken unit. It is up to the dealer and/or the shipper to make things right. I know it is an inconvenience to return and receive another unit but what you want is what you ordered in good working condition. Ultimately it is your call, good luck with your decision.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-21-2016, 05:11 AM   #7
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
Here is my opinion.
If the outer box had been damaged, then likely what occurred was freight damage. I.E., the trucking line or warehouse damaged the box and contents by stacking too high, dropping the unit, or similar. If the outer box had been damaged, then your seller could submit a freight damage claim to the shipper for damage.
But when there is "concealed damage" as in your case, it becomes a big finger-pointing exercise. The freight line can state that they did no damage, as evidenced by the intact shipping box. So did the freight carrier drop this unit off a forklift and cause this damage, or was it done at the factory or at your distributor? No clear way to know.
If you want a different, new unit, in my opinion you will need to be willing to pay the full freight amount to return this to where you bought it. You may be able to negotiate splitting this expense. Or the vendor may offer to cover this. But I don't see how they can not be willing to ship you out a new undamaged unit, which is what you paid for, if you bear the expense of returning this unit to them.
If it were up to me, (and I work at a HVAC distribution warehouse where we have this type of thing from time to time), I would first decide if you are willing to keep it, or if you want a different unit.
If you are willing to keep it, then how easy and convenient will it be for you to obtain warranty service for this unit should there be a problem? And are you able to work on the unit yourself, or are you paying a tech to do this? I also feel that 10% is too low of an amount for you to accept this risk as an end-user. Standard Warranty coverage usually only covers parts, not any diagnostic time/labor or repair labor.
If you are unwilling to keep it, the it may be up to you to be willing to pay to get that unit returned to where it came from. Now they may be willing to do an exchange at no cost to you, or you may have to become pretty insistent. Factor it into the life's not fair category, and make your life easier if that is what it takes.
I guess my main point is to first decide do you want to keep it or not.
If yes, then what discount do you each feel is fair.
If not, then how does this happen.
But don't go fishing for a bigger discount if you in fact don't want to keep it. Decide what you want, and then let the vendor fairly step up to help that happen.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 06-21-2016, 06:37 PM   #8
1966 24' Tradewind
Thanks all. We will bench test it this weekend. If all goes well we will keep it and request a larger discount.
Lewster thanks for the instructions!!
Old 06-22-2016, 02:33 AM   #9
Venice , Florida
Images: 14
If the unit has to be returned, I go not agree that you should be responsible for any expense what so ever. Somebody is responsible and it is not you. Most credit cards today will intercede for you with this issue if that is the way you paid.
Airdreamers
WBCCI #8880
AIR #41310
Old 06-22-2016, 09:18 AM   #10
2015 22' FB Sport
Indianapolis , Indiana
Good morning. Was looking at the VW bus and noticed you are from Versailles Ky.! My wife's Mom and Dad were from Versailles and her cousins still live there!! Small world.
Jim Arnold is offline   Reply With Quote
Old 06-23-2016, 05:46 PM   #11
1966 24' Tradewind
HI Jim, we love Versailles and yes it is a small world. If you're from here it is
Ver-sails not Ver-si. Kinda weird. Here's a pic of some of our VWs -are you a fan of this "breed" ?
Old 06-23-2016, 05:58 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
IMHO that damage to me seems to be inconsequential. If it was mine I would straighten the sheet metal with a pair of pliers, install the unit and forget that it ever got bent.
Superat stultitia.
Old 06-25-2016, 07:12 AM   #13
1972 31' Sovereign
Kerrville , Texas
Hope it turns out ok!
goobscoob is offline   Reply With Quote
Old 06-27-2016, 05:57 AM   #14
2015 22' FB Sport
For Sale
I am a fan. Looking to purchase a Microbus!!
Coleman A/C replacing Coleman A/C? Easyrider06 Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-11-2015 06:41 AM
How do RVs get delivered? TankerIP Off Topic Forum 23 04-04-2012 07:48 PM
Delivered: 1977 Silver Streak 32ft RB, a little rough... Albatrill Member Introductions 2 12-18-2010 04:46 PM
94 AS Delivered Tomorrow:Any tips, Please? SSChanger Member Introductions 5 06-18-2009 07:33 PM
Something new delivered, Mother lost davidz71 Off Topic Forum 20 05-18-2008 10:46 PM
