Old 04-16-2006, 04:24 PM   #1
Coleman AC question
Coleman 13,5K BTU AC
This is the first time I turned on the AC since last fall (well, I did cut it on once during the winter) and it while it's running pretty cold, it doesn't seem to blow as hard. I recall it would blow it further out. Maybe I just forgot how it worked after 6+ months of non-use?
For example now it's 81F outside and I cannot get the inside temperature below 67F after hours of running it on high, is it normal?
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 04-16-2006, 06:08 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Have you cleaned the filter lately? The condensor coils may also need to be cleaned. We also have a Coleman A/C, and it seldom gets below 71 degrees inside when it is over 80 outside.
Old 04-16-2006, 07:43 PM   #3
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I can get 69 degrees out of mine, there are a lot of factors involved in this,how many times the door is opened,window/door seals , also there is a vent in the bathroom to vent the plumbing in cold weather, also cooking . im sure theres more factors, 71 degrees should feel good on a 80 degree day !!!
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 04-16-2006, 07:53 PM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Just fired mine up today. I needed to exercise my 7500 watt Generac, so I hooked it up to the 'Stream and ran it for about 2 hours. 82 outside, 71 inside. Next project is going to be replacing that battery boiling Univolt. Battery took 3 quarts of distilled water
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-16-2006, 08:58 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
A/C Performance Test
Sounds like it should get the trailer cooler, but here is a simple test to see if the unit is cooling to factory specs. Get a couple of kitchen thermometers. Place one at the cooled air outlet of the unit and the other at the return. Run the unit for a while. There should be a difference between the ambient temp measured at the return and the cool air being blown into the trailer of 18-22 degrees F. If it's in that range, the unit is doing all it should. Look for air leaks, solar heating, and the usual cast of heat generating sources .
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
