Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-07-2007, 09:22 PM   #15
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
What ever you end up doing do not install a Larger unit. That is a common mistake that bigger is better. A larger unit will cool quicker and thus shut down sooner. Under this condition you end up with less dehumidifcation. Dehumidifcation is the more important function in order to be confortable in any state that is known for humidity.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-08-2007, 02:22 PM   #16
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Guys,
Originally Posted by HiHoAgRV
I tend to agree with Howie, all of the units I have messed with have the thermal shutoff at the compressor, it wont shut down the fans. Mine had a bad circuit breaker and did the unpredictable so I would swap a $5 breaker and see where it went.
Then again, I can see that your are looking for the forum to support the purchase of a new larger AC, go for it. Your old one is probably on it's last leg
Good suggestion, the first thing I did. Replaced them all while I was at it.
Part of my problem is that when it is running, it’s just not getting the job done. It’s 94 degrees in here right now. Besides, the bigger units are not that much bigger anyway. My neighbor’s 34’ SOB motor home has two ACs the size of mine. You are correct about the humidity here; I drive through a cyprus swamp every day going to work.
Originally Posted by overlander63
Vaughan, it's a little late to tell you now, but the older a/c units used R22 freon.
Thanks Terry,
Not too late at all. Most of my experience has been on automotive units. I don’t even have to look up the pressures for R12 or R134. I’d have to do some research for R22.
On another note, after I washed the dirt dauber nest off the top of the compressor, I plugged the drain line. The runoff partially ran down the sides and partially through the interior skin, flooding my bed in the middle of the night. After clearing the line and replacing the cover, I now need to go the laundry.
Vaughan
Old 07-09-2007, 12:26 PM   #17
HowieE
HowieE's Avatar
Images: 11
Originally Posted by vswingfield
Hi Guys,
As I mentioned before while you have the cover off check the temperature of the suction line. It should be cold to the touch and most likely be wet. If this is not the case the unit has lost it's charge and no judgement should be made under this condition.
Old 07-09-2007, 02:09 PM   #18
vswingfield
1967 24' Tradewind
Images: 32
Hi HowieE,
It is cold and dripping. The unit is blowing cold air, but not keeping up on hot sunny days. Strangely enough, the shutdown phenomenon has not reoccurred since my first post.
Vaughan
Old 07-09-2007, 03:09 PM   #19
HowieE
HowieE's Avatar
Images: 11
OK If the suction line is "wet" and it can't make the grade I yeild to your idea of a larger unit.
Water problems Dbraw Fresh Water Systems 13 06-28-2007 05:55 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 10:36 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 07:37 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 04:53 PM
Lighting problems ramoore53 Electrical - Systems, Generators, Batteries & Solar 1 05-08-2002 11:02 AM
test
