Old 08-13-2016, 07:35 PM   #1
Indianut's Avatar
1972 Argosy 22
Dallas , Texas
Coleman AC problem
Hello all, I have a strange problem with the Coleman AC in my 1972 Argosy. It cools very well, but sometimes I can not turn it off. The fan switch on the left turns the fan off, but the compressor switch on the right will not turn the compressor off. If I kill the breaker it turns off. If I let it run for awhile it seems to be able to turn off then 30 minutes later the compressor will turn back on, but not the fan. When this happens I turn on the fan, let it run for 10 minutes or so, then it will turn off. Then 20 minutes later, with both switches off, the compressor will come back on! Any suggestions? Thanks, Danny
'Dallas' Dan
http://www.wildwheelsthrillarena.com/home.html
Indianut is offline   Reply With Quote
Old 08-13-2016, 08:17 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your AC has a mind of its own. Maybe you can script a movie about the AC that droved the campers crazy.
Maybe a defective switch?
David
Old 08-15-2016, 07:26 AM   #3
Indianut's Avatar
1972 Argosy 22
Dallas , Texas
It was the thermostat! Thanks anyways!
'Dallas' Dan
Coleman A/C replacing Coleman A/C? Easyrider06 Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-11-2015 07:41 AM
Coleman AC Problem Okiegent Furnaces, Heaters, Fireplaces & Air Conditioning 28 07-17-2010 07:30 PM
Coleman AC Leak problem Solved! Excellaphant 1987 - 1989 Excella 0 07-04-2005 07:45 PM
Duo-Therm or Coleman - which to buy ?? George Furnaces, Heaters, Fireplaces & Air Conditioning 7 04-15-2003 10:37 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 03:04 PM
