Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-11-2015, 05:56 AM   #1
1989 32' Excella
Sharon Springs , New York
Coleman A/C replacing Coleman A/C?
Thanks all for holding my hand through this. If I am replacing a Coleman Delta TX, which I'm not sure if it is OE, with a Coleman Mach 8, is there a "drip pan" that I should be getting from AS or Coleman. Haven't been able find an RV shop local (3hrs any direction) that wants any part in working on my unit. Left phone and email messages with Colin Hyde in Northern NY and hopefully he will call back, but just in case, looking at replacing this myself. It seems that a same brand replace should be fairly easy, but I'm sure there is some "new and improved" factors that I'm not aware of, just thought I would start with the drip pan since many people talk about it and I want to connect back to the original drain tube. Any thoughts or experiences would be appreciated...
James
Easyrider06 is offline   Reply With Quote
Old 10-11-2015, 06:41 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
No drip pan. There is a small "kit" you have to order. It is a small elbow fitting that the drip line will attach to. It will place the drip line connect in an odd , front right, position so be aware of that and have enough extra line available to reach that point. All else is standard and it will fit the old 14 x 14 hole perfectly. Unless you have a safe and easy way to lift the AC up top really try to find a shop to do it. A good horse trailer shop will do because they install AC units in some of their high end units. I use a tractor with a front end loader and go slow and careful.
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-28-2020 11:43 AM
Replacing Coleman Delta TX 13500btu A/C tr674 Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-23-2014 08:50 PM
replacing coleman furnace 1988 Excella Catita Furnaces, Heaters, Fireplaces & Air Conditioning 0 11-05-2010 10:42 AM
Replacing coleman AC with Carrier low profile MS325 Classic Motorhomes 11 11-10-2006 10:53 AM
Duo-Therm or Coleman - which to buy ?? George Furnaces, Heaters, Fireplaces & Air Conditioning 7 04-15-2003 09:37 AM
