Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-25-2004, 06:52 PM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
CO problem with furnace :eek:
We just returned from picking up our trailer from Jackson Center and now have a CO problem with our furnace. The furnace worked fine when we dropped the trailer off during the winter for warranty work (i.e., panel replacement due to peeling clearcoat). Now, when we run the furnace there is a funny smell (not propane) and the CO detector starts screaming. I fear that perhaps A/S didn't reinstall the furnace correctly after they took the interior apart to replace the panel. I also noticed that the exterior furnace fitting isn't secure against the outside of the trailer -- there is an opening along the bottom edge where there isn't any caulking. Could the exhaust from the furnace be sucked back in through that opening or is my furnace broken?
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is offline   Reply With Quote
Old 04-25-2004, 07:15 PM   #2
Navigator
Profile:
From the outside of your coach, inspect the inlet / exhaust plate. The top hole (exhaust) pipe should extend tight up against that plate. Same with the bottom. remove the cover plate by removing the long screw in the center of the exhaust, and possibly another plate behind that. Insure that there is a good (polybutylene tape) caulk seal around both plates. If that does not solve the problem, then look inside your furnace at the asbestos seal between the igniter plate and the burn box. This is a serious concern.
Dick
Navigator is offline   Reply With Quote
Old 04-25-2004, 07:35 PM   #3
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I had a CO problem with my furnace. I found that the exaust/intake plate only had 2 screws instead of the 4 holding that plate on. Once I added the additional 2 screws and tightened the plate down properly, the CO problem disappeared.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
furnace problem nwclassic Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-12-2007 12:15 AM
R & R a Suburban Furnace Janet's Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 08:19 PM
Furnace problem, Real technical. Navigator Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-03-2004 10:31 PM
furnace problem..... norbert Furnaces, Heaters, Fireplaces & Air Conditioning 12 11-17-2003 09:50 AM
Furnace problem Paul Daugherty Airstream Motorhome Forums 20 02-19-2003 04:31 PM
test
