Old 05-17-2015, 03:39 PM   #1
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Cleaning AC drain hose
Greetings
Every month we have to put some special solvent into our home ac drain pipe. On the Airstream, does anyone ever clean out their AC drain hose? If so, what do you use and how do you access it? I know the drain on my unit exits on the street side wheel well but I have never seen the other end at the AC.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-17-2015, 03:47 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
In the old Bambi II I used vinager and high pressure air to open the hose up. I need to check the drain on the Safari, I am getting a lot of water running down the sides lately when running the AC. Humidity has been pretty high.
MICHAEL
Old 05-17-2015, 04:09 PM   #3
2006 25' Safari
Images: 8
Where is the intake on the hose? I am sure it is at the pan but have not located it. I have a Dometic unit OEM.
Old 05-17-2015, 05:43 PM   #4
AWCHIEF's Avatar
Images: 33
Not sure where it is in the 2006 (same year as mine). I have not made effort to find it. The previous owner of my trailer had new AC put in by Jackson Center about this time last year, so it might be different than yours. If you pull the inside shroud you should be able to see it with some looking around.
The outlet should be somewhere underneath around one of wheel wells.
MICHAEL
Old 05-17-2015, 05:55 PM   #5
2016 30' Classic
Erie , Colorado
On my 2014FC the hose came up the roadside wall into a T connector. From their it went to each of the drain cups. Get a very stout roll of weed wacker plastic whacker stuff and run it up the tube. Or take off the inside AC cover and you could run an electrical snake up from the outside and put something on the end, small piece of cloth, and pull it back out. This all worked on a 2014. YMMV.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 05-17-2015, 06:03 PM   #6
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
If your tube (air conditioner) is really clogged up go to an auto parts store and get the longest speedometer cable you can. Remove the outer shield and chuck the inner cable in your drill. Run it up and down the drip tube and watch the krap come out. It is possible to come through the tube if it is old and corroded so be careful.
mhilley is offline   Reply With Quote
Old 05-17-2015, 07:02 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I managed to keep mine clean with air pressure. The first time I blew back up the line... I don't recommend that. Blowing down the line is better.
Aaron
WBCCI #XXXX AIR #2495
Old 05-17-2015, 07:27 PM   #8
AWCHIEF's Avatar
Images: 33
Ditto on not blowing up the hose, lesson learned the messy way.
MICHAEL
Old 05-17-2015, 07:46 PM   #9
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I occasionally attach my wet/dry shop vac to the outlet and suck out anything I can. This is also how I clear household AC condensate drains also. No dis-assembly required, no mess, effective.
Old 05-17-2015, 09:00 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
This is what we do...
Also, we use Clorox in the line for house.. 1/2 cup a month. Yes, it is "overkill".... Then after an hour use wet/dry outdid to pull some air thru line.
Old 05-18-2015, 11:50 AM   #11
2010 27' FB Flying Cloud
Kansas , Topeka
A filter helps too
I had a mud dauber build a nest in the drain tube on our 23'.
A simple plastic filter in the line prevents that happening again. The critters apparently like the moisture in the tube and saves major problems.
BDowse is offline   Reply With Quote
Old 06-12-2017, 07:39 PM   #12
Plano , Texas
How do you access the drain hose fron the top? Can you take the ac cover off?
Airone is offline   Reply With Quote
Old 06-12-2017, 07:43 PM   #13
AWCHIEF's Avatar
Images: 33
You can access the hose by removing the inside vent cover. You should be able to look up and see it.
MICHAEL
Old 06-12-2017, 08:10 PM   #14
CRH
1995 25' Excella
xxxxx , xxxxxx
I run weedeater line up mine.
CRH is offline   Reply With Quote
Can rainwater get in A/C drain hose By the Bay Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-24-2009 09:35 AM
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 10:21 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
drain hose at rear of trailer frieda v Plumbing - Systems & Fixtures 7 06-10-2004 07:59 PM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 07:15 PM
