05-17-2015, 03:39 PM
2006 25' Safari
St. Augustine
Cleaning AC drain hose
Greetings
Every month we have to put some special solvent into our home ac drain pipe. On the Airstream, does anyone ever clean out their AC drain hose? If so, what do you use and how do you access it? I know the drain on my unit exits on the street side wheel well but I have never seen the other end at the AC.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
05-17-2015, 03:47 PM
Biloxi
, Mississippi
In the old Bambi II I used vinager and high pressure air to open the hose up. I need to check the drain on the Safari, I am getting a lot of water running down the sides lately when running the AC. Humidity has been pretty high.
MICHAEL
05-17-2015, 04:09 PM
2006 25' Safari
St. Augustine
Where is the intake on the hose? I am sure it is at the pan but have not located it. I have a Dometic unit OEM.
05-17-2015, 05:43 PM
Biloxi
, Mississippi
Not sure where it is in the 2006 (same year as mine). I have not made effort to find it. The previous owner of my trailer had new AC put in by Jackson Center about this time last year, so it might be different than yours. If you pull the inside shroud you should be able to see it with some looking around.
The outlet should be somewhere underneath around one of wheel wells.
MICHAEL
05-17-2015, 05:55 PM
2020 Classic 33
Box Elder
, South Dakota
On my 2014FC the hose came up the roadside wall into a T connector. From their it went to each of the drain cups. Get a very stout roll of weed wacker plastic whacker stuff and run it up the tube. Or take off the inside AC cover and you could run an electrical snake up from the outside and put something on the end, small piece of cloth, and pull it back out. This all worked on a 2014. YMMV.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NŲVPN
05-17-2015, 06:03 PM
2000 23' Safari
Vero Beach
If your tube (air conditioner) is really clogged up go to an auto parts store and get the longest speedometer cable you can. Remove the outer shield and chuck the inner cable in your drill. Run it up and down the drip tube and watch the krap come out. It is possible to come through the tube if it is old and corroded so be careful.
05-17-2015, 07:02 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I managed to keep mine clean with air pressure. The first time I blew back up the line... I don't recommend that. Blowing down the line is better.
Aaron
WBCCI #XXXX AIR #2495
05-17-2015, 07:27 PM
Biloxi
, Mississippi
Ditto on not blowing up the hose, lesson learned the messy way.
MICHAEL
05-17-2015, 07:46 PM
1973 21' Globetrotter
Houston
I occasionally attach my wet/dry shop vac to the outlet and suck out anything I can. This is also how I clear household AC condensate drains also. No dis-assembly required, no mess, effective.
05-17-2015, 09:00 PM
1999 34' Excella
Hillsboro
This is what we do...
Also, we use Clorox in the line for house.. 1/2 cup a month. Yes, it is "overkill".... Then after an hour use wet/dry outdid to pull some air thru line.
05-18-2015, 11:50 AM
2010 27' FB Flying Cloud
Kansas
, Topeka
A filter helps too
I had a mud dauber build a nest in the drain tube on our 23'.
A simple plastic filter in the line prevents that happening again. The critters apparently like the moisture in the tube and saves major problems.
06-12-2017, 07:39 PM
2019 Basecamp
Plano
, Arkansas
How do you access the drain hose fron the top? Can you take the ac cover off?
06-12-2017, 07:43 PM
Biloxi
, Mississippi
You can access the hose by removing the inside vent cover. You should be able to look up and see it.
MICHAEL
06-12-2017, 08:10 PM
1995 25' Excella
xxxxx
, xxxxxx
I run weedeater line up mine.
06-13-2017, 04:38 AM
2019 Basecamp
Plano
, Arkansas
Thanks. I'll try both.
07-23-2017, 03:25 PM
2018 30' Classic
Ivins
, Utah
How does that cover come off? Does it snap off by pulling on it? I haven't been able to spot any screws.
07-23-2017, 05:32 PM
2018 30' Classic
Ivins
, Utah
Ahh never mind. I found the screws securing the cover.
07-23-2017, 06:52 PM
2002 22' International
2019 25' Flying Cloud
Austin
Use clothesline metal rope
Years ago I had about 8 feet of left over plastic covered clothesline wire rope. I decided to keep it in my RV tool box for some yet to be decided project. That opportunity appeared one time when we parked, turned on AC, and then left to go to store. When I returned water was dripping down the interior wall. It took a little time for me to diagnose it. But I took the wire rope, fed it up the drain tube located on the street side wheel well. I ran the rope all the way up to the AC drain pan. Almost suddenly water just flooded out the clear tube and the interior leak stopped.
I have kept this plastic wire rope in my box ever since. But I now always check the wheel well area for good drainage whenever we first park.
08-03-2017, 09:28 PM
2006 25' Safari
St. Augustine
Recently while I was retrofitting my AC with an automatic thermostat I wanted to clean the drain hose. I was able to draw a cable fisher line through it from the inside but not all the way. I tried it from the outside and hit the same point somewhere at the roof curvature it stops. Is that normal or should I be able to go all the way?
09-21-2017, 09:13 AM
2019 Basecamp
Plano
, Arkansas
I haven't figured out my drain. It drains across the roof. Someone disconnected the drain hose from the ac side. I don't know Where it's supposed to attach. I can see the hose from the inside but it's not attached to anything.
