Old 10-15-2007, 07:32 AM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Check your Furnace heater for CO!
Sad story from JohnHD's neck of the woods:
Clydesdale Community Shocked By 4 Deaths - News Story - WISC Madison
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-15-2007, 04:24 PM   #2
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
How sad! Thanks Pick for the reminder, especially with cooler weather coming on. I'll change the batteries in my CO detector. I wonder what type of propane heater they had.
Traveling With Elvis
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 10-16-2007, 09:33 PM   #3
Wagon Master
kwoolston's Avatar
2012 30' International
Sanger , Texas
Exclamation propane gas seapage
This is very sad. A message for caution for all of us.
I have a heater that slowly emits gas when not running. When runnng, no gas smell - when not running, propane, although a very small amount. I heat for a short period, then shut off gas at the tanks (new AS for us, a 78 Soveriegn, just finish remodel and first time out in it last weekend).
Any suggestions on the small leak?? Everything else gas works fine - no other problems, but of course, cant use anything else as the leak exists and is prominent when gas is on, just can't smell it when the furnace is also running.
Any ideas on the fix??
kwoolston is offline   Reply With Quote
Old 10-16-2007, 11:01 PM   #4
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
We purchased one of those little carbon monoxide detectors and leave it plugged in when we are "hooked up to power"... they are available at local hardware stores. Anyone see any that are battery powered? Never hurts to be careful. Another $30 is nothing compared to one's safety!
kwoolston, I would do the propane valve and joint checks with the soapy water routine... and also inspect all the lines. Go to your nearest large propane dealer (company that just sells propane and propane appliances) they can probably give you ideas on how to check and what to look for! This could get worse at a bad time! You and your family are too important to let a leak go by unrepaired.
Mrs. NorCal Bambi (traveling in S Tardis ~ from the Great State of Jefferson)
CaddyGrn is offline   Reply With Quote
Old 10-17-2007, 12:57 AM   #5
1960 24' Tradewind
santa barbara , California
hello Kwoolston,
find that leak ,don't use the gas until you find it .Very dangerouse situation you have going on .You need to locate the leak before somthing happens !You can use the dish soap /water method ,spray soapy water on the gas connections at the heater and around the valve and control .If you spot bubbles ,youve found a leak .I turn off the gas at night anyway and
the hot water in the water heater is still pretty hot in the morning
I will heat the trailer pretty good then shut of the gas at the tanks .I just feel better about not having taken a chance of having a leak .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 10-17-2007, 06:12 AM   #6
Sugarfoot's Avatar
1960 24' Tradewind
1963 16' Bambi
Originally Posted by CaddyGrn
We purchased one of those little carbon monoxide detectors and leave it plugged in when we are "hooked up to power"... they are available at local hardware stores. Anyone see any that are battery powered? Never hurts to be careful. Another $30 is nothing compared to one's safety!. . . . Mrs. NorCal Bambi (traveling in S Tardis ~ from the Great State of Jefferson)
I got mine at either Wal-mart of Home Depot, I can't remember which. It's manufactured by Kidde ~ a combo smoke and CO detector that includes a voice-over with the alarm. I know it works VERY WELL for smoke (have to shut the partition or disable when making toast) and would hope it works equally well for CO.
Old 10-17-2007, 07:10 AM   #7
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
So sorry to hear about this family... This is the reason we have replaced our nearly 30 year old furnace with a new one.... and we NEVER travel without working smoke detectors, carbon monoxide detectors and propane detectors...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 10-17-2007, 08:10 AM   #8
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
location
Geez, what a sad story. Just to clarify for me, where exactly is the best place to mount a CO detector? The news story says that CO sinks, implying that the best place might be near floor level. I thought the directions for my detector said to mount fairly high on a wall- Now I'm concerned. Where do these things go for optimum reliability?? Thanks!
tphan is offline   Reply With Quote
Old 10-17-2007, 08:22 AM   #9
davenpow's Avatar
1975 31' Sovereign
Canby , Oregon
CO detectors should be mounted 6 to 9 " from the floor. I used the bathroom/galley wall, short electric run to the 12 volt panel under the sink.
Seems to working well, chirpped when I installed the new furnace, until I found the leak.
davenpow is offline   Reply With Quote
Old 10-17-2007, 11:30 PM   #10
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Thanks.
Thanks! I will check it out, looks better than the current one we have! Always a good idea to consider safety!
Old 10-18-2007, 04:50 AM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes quite a tragedy.
check your equipment AND get a detector!
john
you call them ferrets, i call them weasels.
Old 10-23-2007, 06:16 PM   #12
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Our natural gas/propane detector is within one foot of the floor. The battery powered carbon monoxide detector and the smoke detector are installed above our bed approximately one foot from the ceiling.
Regarding placement of the CO detector, as with so many things, it depends. We are concerned both with gas leak (which would require a gas detector) AND with the products of combustion (especially Carbon Monoxide) from an appliance intended to warm the air.
Here's what a site dedicated to preventing death and injury from CO states, "When considering where to place a carbon monoxide detector, keep in mind that although carbon monoxide is roughly the same weight as air (carbon monoxide's specific gravity is 0.9657, as stated by the EPA; the National Resource Council lists the specific gravity of air as one), it may be contained in warm air coming from combustion appliances such as home heating equipment. If this is the case, carbon monoxide will rise with the warmer air."
The source of this info is Carbon Monoxide Detector Placement - The Silent Killer
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 10-23-2007, 06:37 PM   #13
Central , Mississippi
I just installed one with a 6" gap to the floor and in the vacinity of a duct. So far so good with no beeps!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
water heater/furnace combo tracker Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-02-2006 10:02 PM
Replacing a furnace with catylitic heater? FOB Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-15-2006 09:13 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
