Old 06-25-2005, 11:56 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Check your A/C cover!
I had to get on top of the AS today to remove the A/C cover to check for bugs. (See my gnat attack thread).
I did not find any bugs, but I did find something that bugged me.
The mounting screws for the plastic cover were put it so crossed that the heads were literaly cutting into the plastic making the hole bigger and oblong. Soon there would be no material left for the screw to hold.
This is a new Dometic Penguin A/C purchased and installed about three years ago. The rear two screws holding the cover on were put in so crossed it looked like they just put the screw in w/o pre-drilling and tried to find the mounting hole in the metal frame. Very poor workmanship.
I always wondered why the replacement tops were so easily available. I bet these things go flying off at highway speeds all the time!
I was able to add some washers to keep the screw heads from cutting into the plastic and I got the screws straightened out.
May want to give yours a look before its too late!
-Tim
theVAP - Airstream Podcast
Old 06-26-2005, 07:53 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Some big fender washers should do the trick. I see a Coleman shroud about once a month lying beside I75 down here.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-26-2005, 07:56 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
you should scoop those up, and sell 'em on e-bay. they get big-bucks for those things!
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 07:02 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
