Old 02-27-2011, 10:53 AM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
cheap heat rv comfort systems - electric conversion of furnace?
I just learned about this. It is an add-on for electric heat for Atwood furnaces.
Anyone try this out? Regardless of its name, it ain't cheap ($800).
CheapHeat
However, it uses existing fans, so if you don't like your fan noise, you
probably won't get less noise.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 02-28-2011, 11:37 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
It wouldn't fit in my trailer without significant rework to the cabinetry. There just isn't room. I suspect that most Airstream installations are the same.
Many SOBs are designed with all kinds of extra space around systems components so I suppose it would work better for them.
I would imagine that the key problem of electric heat would remain -- that there isn't enough electrical power to get the job done unless you have a 50A shore power system and are able and willing to run a 240v feed from the panel to the heater.
Old 02-28-2011, 12:54 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I'm suspicious of any product that doesn't have any actual pictures of the product on the website - just drawings and clip art.
Stephanie
Old 02-28-2011, 01:03 PM   #4
cameront120's Avatar
1972 25' Tradewind
I'm suspicious of any product claiming to be "green" without giving any explanation supporting this claim.
North Vancouver, BC
Old 02-28-2011, 01:42 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I'd think if you had the cabinet space and wanted a little electric heater, one of those fan driven electric wall heaters like they put in apartments would be a good choice. Though it wouldn't be hooked into the existing system so it couldn't heat your tanks, but just for heating the room it would work pretty well. Then if you're boondocking, use the RV heater, and if you're plugged in use the electric. And they only cost $100.
We just keep an electric space heater to pull out and use if we're plugged in. Mostly because it's quieter than the RV heater.
Stephanie
Old 03-01-2011, 08:47 AM   #6
hshovic's Avatar
Bozeman , Montana
Images: 20
Thanks to all for the notes. I agree. Probably not for Air Streamers.
Hank
Old 03-01-2011, 09:39 AM   #7
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I like the idea of this heater as 1 of my MH's furnaces has a pinhole in the combustion chamber. This would allow me to use it again without needing to replace. Too bad there's no details about the product. I was trying to found out things like measurments & wattage (amps).
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 03-01-2011, 10:02 AM   #8
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Electric Heater
You would have to be hooked up to the grid all the time to even consider the electric addon.
Probably a lot cheaper to replace your propane unit than install an electric addon!
Propane furnaces are available from numerous sellers, including many large auto parts suppliers, and prices are competitive.
A portable electric ceramic heater will do the job at minimum cost, and can be located where you want the heat.
For diesel units, there are many good diesel heaters that are very efficient and quiet and can be installed in varied locations.
Dave
Ricky
Old 03-01-2011, 11:08 AM   #9
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
I looked into this a few months ago for the 27FB. Seems to be room for it given the furnace under the sofa in that floorplan.
I'll pursue it again and let you know what I find out.
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 04-14-2012, 10:54 AM   #10
2009 25' FB Flying Cloud
Toronto , Ontario
Send a message via Skype™ to pixelhead
Found this on YouTube:
Looks interesting.
pixelhead is offline   Reply With Quote
Old 04-14-2012, 04:28 PM   #11
fmrcaptevil's Avatar
Weldon Spring , Missouri
If they don't sell, perhaps marketing that video as a cure for insomnia would.
You mess with me, you mess with the whole trailer park.
fmrcaptevil is offline   Reply With Quote
Old 04-15-2012, 01:03 PM   #12
The irony is that if you hate paying for propane that much, you are also probably way too cheap to spring for that mod for your furnace...(you'll be just fine tripping over a couple of space heaters from Walmart).
Old 04-15-2012, 01:10 PM   #13
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I guess the question is whether the electric conversions are indeed more efficient than the propane systems. I've seen analyses of these, but can't remember what they said.
Lynn
WBCCI 21043
Old 07-17-2012, 01:18 PM   #14
2009 30' Classic
Springfield , Oregon
Electric Heater
I just bought an electric heater for my Airstream online for $495.00 from RV Comfort Systems. It took me about a day to install it. But itís really cool, now when I plugged into an RV park I an heating with electric on there dime. Then when I go on the road I just flip a switch by the thermostat and I am back on gas.
VERY COOL
travel5r is offline   Reply With Quote
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
Suburban Furnace Selection MDSilverado Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-31-2011 09:40 AM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
