Old 01-29-2016, 11:37 PM   #1
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Ccc2 or furnace issue?
The outside temp was44f but has dropped to 39f. I am setting the ccc2 to 62f
If I set the ccc2 to auto it fires up the heat pump, it cycles a few times and stalls, I assume to frosting.
If I set the ccc2 to furnace it will fire up the furnace once, maybe twice, then nothing will happen.
I have lots of propane, the stove works fine...
Any ideas why the furnace is not playing the " keep me warm game" ?
Thanks!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 01-30-2016, 04:19 AM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
First: The heat pumps simply will not work below about 40 degrees F. They are designed to work as a heat source above 45 degrees F.
Second: We had the same issue with our 2015 30' FC. Furnace would kick on correctly, light up fine and then the propane would shut off. It would recycle itself between 5-7 times and then finally kick on and stay on. Everything in the system was replaced except the propane valve within the furnace and the sail switch, including the valve at the tanks.
With all this done it worked at the shop, but I went to storage the next day and it went through the cycle again. So I took it back to the shop and this time they replaced the valve in the furnace that controls the propane flow - it worked.
I've tested it periodically at 15 degrees F and then yesterday at 28 degrees F and both times it fired the first time, stayed on until the chamber got too hot, kicked off which it is supposed to do, then came back on and stayed on until trailer was warmed up to 70 degrees F.
So, long story shortened - you might have them check that valve. As our main board was replaced, igniter was replaced, tank valve was replaced. OUR yours could be as simple as the sail switch which others with 2014 - 2015 have had issues with.
Ours was all done under warranty. We also carry two small ceramic heaters all the time and always have, just in case.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-30-2016, 07:55 AM   #3
Gsmblue's Avatar
Bend , Oregon
Thanks Bud, I will let the dealer know!
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Another Furnace Issue PharmGeek General Repair Forum 13 04-19-2014 04:22 PM
Argosy Furnace issue mprokop87 Argosy Motorhomes 0 03-11-2014 06:25 AM
Atwood furnace issue--Help?! Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-01-2005 08:31 AM
