Old 06-30-2007, 10:06 AM   #1
Tidal's Avatar
1972 31' Sovereign
Cordova , Tennessee
Caulk the old screw holes??
Just removed a dead Armstrong. This required removing 50 screws that held down flashing.
I'm thinking I should buy new stainless screws to fill the holes then caulk over them.
Would there be a better solution?
Looking forward to some cooolness asap!
Many Thanks!
Mike of Memphis
Tidal is offline   Reply With Quote
Old 06-30-2007, 12:11 PM   #2
For this sort of job I've just applied a length of aluminum tape. This is the high quality tape, about 2 and a half inches wide, used to join sections of ducting in ventilation systems. You could apply two layers to beef it up. I would rather trust this to keep out water than a heap of screws. It's also very quick. For belt and braces, I've put the screws on with sealant, and then used the tape on top. This is a useful trick with the joint between the roof and the awning. When you walk on the roof you might see this joint opening up as you move. This is what caused me to tape this joint.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-30-2007, 03:46 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I'd go with a rubber washer topped with a stainless flat metal washer and the stainless screw. No caulk. Don't over tighten.
Patching Old Screw Holes on Zolatone? cloud55 General Interior Topics 6 01-25-2006 06:42 PM
Screw holes in Tradewind floor yochanan Repairing/Replacing Floor &/or Frame 1 01-21-2006 11:50 PM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
caulk removal Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 10-17-2002 08:56 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
