Old 01-12-2010, 10:45 AM   #1
2000 34' Limited S/O
Jamestown , North Carolina
Catalytic Heaters
I have an Olympian Wave 8 and am wondering what my options are for mounting locations. Can you place it anywhere there is sufficient surface for mounting?
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 01-12-2010, 12:32 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Two things to consider...nearby LP line to tap into and whatever clearances you need for side, top and front.
I would say that 95+% of the ones I have seen have been mounted on the bulkhead just to your left when you come through the door. That is typically the side of the cabinet where the stove is located. YMMV.
Aaron
WBCCI #XXXX AIR #2495
Old 01-12-2010, 02:03 PM   #3
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
We're discussing this very same topic on this thread.
http://www.airforums.com/forums/f462...ers-56570.html
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Catalytic Heaters niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 47 05-24-2016 08:41 AM
olympian catalytic heaters kingfisher24 Winter Living 15 03-01-2010 04:22 PM
Catalytic Heaters from Vintage dudebb Furnaces, Heaters, Fireplaces & Air Conditioning 12 10-23-2007 04:06 PM
Question on Catalytic Heaters tlavergne Furnaces, Heaters, Fireplaces & Air Conditioning 15 08-23-2007 10:19 PM
Catalytic Heaters - Who Wins? Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-18-2002 07:09 AM
