12-13-2011, 05:59 PM
Cedar Lake
, Indiana
Catalytic heater vs. furnace
okay here are a couple of questions and concerns.....
regarding a catalytic heater and a suburban furnace
Which uses more propane, is more efficient?
Which is safer to leave running during the night?
carbon monoxide?
the lp gas alarm begins when the furnace turns on.
below freezing temps is when these are used at night to protect the water lines and stay comfortable.
All information is appreciated
hoosiergypsy
12-13-2011, 06:22 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
There will be lots of input on this topic. Here is mine.
A catalytic heater is probably more efficient in terms of propane use. More of the heat it produces heats the objects in front of it, and not the air around it.
A furnace will burn more propane, and use energy to run the fan, but it will make the entire trailer warmer quicker. Yes, there are ducts pointed at the holding tanks, but, a trailer warmed with the catalytic heat will radiate some heat to the tanks.
Tanks not freezing are more a function of how cold it is where you are.
Boondocking, a catalytic heater is easier. I have used one when outdoor temps are in the single digits and stayed warm enough.
The furnace takes a lot of battery power to run the blower. About one really cold night will have the batteries dead. However, if you are hooked to electric power, the furnace will keep the trailer nice.
Good Luck,
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
12-13-2011, 07:00 PM
Central
, Mississippi
Yeah, exactly what " jdalrymple " said.
I will add that we have found when we do have full hookups, we use small cube heaters, without full hookups the furnace is a battey killer so we use the cat heater. We have only fired up the central heat once in the last 2 years.
Our '63 we are rebuilding will not have a central heat for just those reasons.
12-13-2011, 08:40 PM
2012 25' Flying Cloud
Battle Lake
It is dangerous to use catalytic heaters without ventilating the trailer to replace the oxygen they use in combustion, who knows how much? I don't like sharing my oxygen supply with them.
There are safer alternatives, the furnace, heat pump, and electric space heaters.
doug k
12-13-2011, 08:56 PM
Oswego
doug k
ditto.....DITTO!
-Rich-
12-13-2011, 09:23 PM
Wise Elder
2010 30' Classic
South of the river
Hello Hoosier
Well let's take these one at a time then.
Suburban furnace typically 75% efficient. Catalytic heater typically 98% efficient. But to run a catalytic heater safely requires you to leave a window open which more than overcomes the difference in efficiency.
Suburban furnace unless there's something bad wrong with it
Well it's like this.
Catalytic heaters produce very little carbon monoxide when new but as the catalyst degrades over time the amount of carbon monoxide they generate gradually increases. And, it is emitted directly into the interior of the trailer, where you breathe it. In general it is not economically feasible to replace the catalyst so it becomes a matter of how much carbon monoxide you are willing to breathe before you replace the whole heater.
A suburban furnace has a heat exchanger so any carbon monoxide it generates will be blown outside, where it doesn't matter much, until the heat exchanger rusts out and fails, which takes a long time. Once the heat exchanger fails, the entire furnace should be replaced.
Then there's something wrong with the furnace and you should fix it before you use it any more. Furnaces that work properly don't leak propane.
hoosiergypsy
Other facts to consider
1) Catalytic heaters produce less heat and will not work well enough in really cold weather. Maybe down to 40 degrees or so depending on the size of the heater and the size of the trailer.
2) Catalytic heaters produce a fair amount of water vapor which will tend to condense on the walls and elsewhere and create a variety of problems, mold, etc. This is more of a problem at lower temps and with extended use than it is for the occasional 55 degree night
3) Finding a safe place to mount a cat is something of a problem because of the clearances required. To do it right you have to keep it away from any kind of combustibles - table cloth, curtains, bedspread, and there aren't very many places that qualify. Usually people mount them right by the outside door.
4) There's no ductwork so distribution of heat becomes a problem. Often furnaces are installed without enough ductwork but at least the idea is there.
5) The only real benefit of a cat is that they don't require any electricity to run so they appeal to people who boondock in cold weather. The suburban furnace uses electricity and when all you have are batteries it can run them down in 1 or 2 cold nights. But there are other safer alternatives available, though, look for my threads on the topic in the furnace & air conditioning section of this site.
Hope this helps
Jammer
12-13-2011, 09:27 PM
1975 29' Ambassador
Reno
, Nevada
A catalytic heater runs at about 5,000 8,000 BTU/hr and the furnace about 20,000 to 30,000 BTU/hr (a gallon of propane is about 93,000 BTU)
The catalytic heater is 'always on' and relies on conduction and radiation to disperse its heat. The furnace is forced air and runs on a duty cycle depending upon the thermostat call.
The catalytic heater is not (usually, most models) vented which means all combustion products remain in the trailer unless there is proper ventilation. Note that this isn't only CO2 and CO but also water vapor, which can be a problem.
The furnace uses a vented combustion which reduces its efficiency some but keeps all combustion products outside.
The furnace needs about 100 watts of electricity to power its fans and controls. (batteries have about 12 watt hours per pound so the typical trailer may have a bit over a kilowatt hour available)
When the propane tanks get cold, they can't 'boil off' gas very fast so that might be a problem trying to run both the furnace and the water heater and the oven in very cold weather depending upon your tank size.
12-13-2011, 10:28 PM
Maniacal Engineer
Lopez Island
I'd rather use one of these, since it avoids the excessive electricity consumption and noise of the forced air furnace.
Dickinson Newport Propane Boat Heater / Fireplace, P12000, Dickinson Marine's largest propane model, is ideal for boats up to 30/36 ft. The combustion process is completely isolated from the inside of the boat by the unique, direct vent design. A built-in blower provides good heat circulation for your boat.
- Bulkhead mounted boat heater / fireplace
- Non-rust stainless steel construction
- Unaffected by motion, winds or weather conditions
- Fuel Consumption: Low 1 lb - 5.5 hrs, 20 lb - 110 hrs, High 1 lb - 3.9 hrs, 20 lb - 78 hrs
- Heat output for the P12000 is 7,000 - 9,700 BTU
- Bart
12-13-2011, 11:40 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Lots of real good info here and I agree with all of it. Bryanl- If the furnace requires a 100 watts and the average trailer may have 1 kw-hr of energy available, I guess that means that you can run the furnace about 10 hours (constant) before the batteries are depleted. Is this correct? Taking this one step further if the typical cat heater puts out about one third the heat of the furnace than the furnace only needs to run one third of the time to put out the same heat as the cat heater. So instead of running the cat heater for 10 hours you run the furnace for 3.33 hours. Then the batteries will make it for 3 days (comparing apples to apples- same heat output).
I will only add that all the cat heater manufacturers that I am aware of specifically state that you should not operate the cat heater when you are sleeping. With that kind of warning, I don't think that I would sleep very well with one operating. I would rather just run the furnace and recharge the batteries in the morning with my 1,000 watt Honda if it is needed.
Dan
12-14-2011, 06:42 AM
Wise Elder
2010 30' Classic
South of the river
TouringDan
The battery life question is important enough that a detailed trailer-specific answer is worth getting rather than rules of thumb.
Furnaces vary in their power consumption from one model to the next with the ones in Airstreams using anywhere between 5 and 12 amps. Battery installations vary with trailers having one or two 90 aH batteries in a stock configuration with many people adding extra. In my trailer I have 180 aH of batteries and the furnace draws 10 amps so the max I can run the furnace is 18 hours. In practice I find I can run it for one overnight stay.
Cat heaters generally don't use any electricity at all, which is the reason people like them.
Barts mentions the Newport heaters which are one of several alternatives which I compare here:
http://www.airforums.com/forums/f427...ers-72237.html
And here are a couple more to consider that are intended for residential use. I'm not aware of any successful Airstream installations. They're vented gas heaters that don't use a fan:
http://www.airforums.com/forums/f427...ity-74936.html
12-14-2011, 06:58 AM
1993 34' Excella
Estancia
, New Mexico
I like the Boat heater above because it also has a purdy flame, a bit pricy as is most boat stuff.
New cats should have an auto O2 or CO sensor which shuts it down before it croaks you.
I have been having the cat heater debate with myself for a couple of years, and since I have a Honda 2000 inverter genny the batt depletion argument is nil. I can also use it to power a small ceramic heater.
12-14-2011, 09:50 AM
Wise Elder
2010 30' Classic
South of the river
A final fact to consider is that many people who do cold-weather boondocking don't heat the trailer at night, instead relying on sleeping bags for comfort. It's then only necessary to run the furnace for a relatively brief time in the morning and evening.
12-14-2011, 10:13 AM
1984 31' Airstream310
Ajo
Maybe with trailers,but we've been below zero many times and had no problems. I do miss the CAT heater we had in our former Excella trailer, though.
12-14-2011, 10:25 AM
Port Orchard
Cold is a relative temperature, but to me it means below freezing. I'm surprised it doesn't mean that to someone from Minnesota.
I would be very apprehensive about the plumbing without heat below 32F. It will definitely freeze at some point in time. I guess one could hope it will not freeze before you turn the furnace on again in the morning.
I agree with Jammer's earlier post about the alarm going off.
That is not normal and could indicate a serous problem. I would recommend finding and fixing it, whether it is the furnace or the alarm.
Ken
12-14-2011, 01:42 PM
Wise Elder
2010 30' Classic
South of the river
Hi Ken
Well yes cold is a relative thing and to be sure by Minnesota standards cold doesn't really start until you get to the temperatures where there is some question whether enough propane will vaporize to run the furnace in your stick house, usually around -35 or so.
Seriously, though, Airstreaming in sustained below-freezing temperatures is a subject in its own right. I believe there are two approaches in widespread use: 1) camp where there's shore power (or a generator running most of the time); 2) don't use the plumbing. I myself subscribe to a third approach -- I keep the trailer parked inside all winter.
Seems like the people with catalytic heaters use them in spring and fall weather where it drops down close to or a little below freezing at night and is warm in the day, where frozen pipes aren't so much a problem.
12-14-2011, 01:46 PM
Wise Elder
2010 30' Classic
South of the river
I posted a chart in an older thread on this. Much depends on how full the tanks are, their size, and the wind. In general the Airstream heating system will work overall down to around -10 F or so as long as both tanks are reasonably full (1/4 or more). Below that temperature two things happen. The tanks won't vaporize, and even if they did, the furnace won't produce enough BTUs to heat the interior to 70 degrees.
12-14-2011, 02:07 PM
Port Orchard
I've spent nights in our old Bigfoot at 10 below and somewhat colder. However it had dual pane windows and not so so many of them plus 1 1/2" Styrofoam everywhere else. Supposedly it was rated to 40 below, unfortunately I am not. I am guessing it would probably be not too bad in the Airstream because the furnace is substantial. But I'm thinking there would be frequent trips to the propane dealer. Our trailer was expensive enough as it is, but I would have sprung for a cold weather package if they offered one.
Ken
12-14-2011, 02:26 PM
1964 17' Bambi II
Schererville
, Indiana
Hi Hoosier Gypsy! I'm right down 41 from you....we should do tours sometime! We've used both the furnace & catalytic on our 31' Sovereign in the dead of winter. We turned off the catalytic when we went to bed, but it was pretty comfy for watching tv with it on. We ran a generator to run fans, etc. The Bambi II that I'm restoring won't have a furnace. It's so small that a catalytic heater will be plenty of heat. I'm running just a little ceramic heater in it right now while I work in it & it's plenty warm. You should always have a vent cracked if you're going to used the catalytic (as everyone else has said). They throw a lot of heat!
Becky
1964 Bambi II
1988 Avion 32S
12-14-2011, 02:53 PM
Wise Elder
2010 30' Classic
South of the river
I've stayed in mine at -10 strictly as a test. 1 gallon of propane every 3 hours so with the stock 40# tanks on there you can make it a little over two days at those temps.
12-15-2011, 07:05 AM
Cedar Lake
, Indiana
Hi everyone,
not certain if my responses to each were sent? thank you all for your comments. I have all 3, catalytic, suburban and space heater. Concern was usage of propane, safety and frozen water lines.
I am going to have the furnace looked at soon. I did have it serviced within the past year.
Keeping both propane tanks (30) filled and open will be something I begin to do.
Presently full hookup. both holding tank valves are open and when really cold below 27' use only fresh water tank and wrap the water connection outside. the coldest it has been is 14' at night, no 24hr below freezing yet...at that point I will remind myself I am on wheels or winterproof the lines which I really do not want to do.....public facilities are out of my comfort zone.
thank you again all for your comments..
grace and peace,
hoosiergypsy
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
My furnace blows... out its own flame
godaddy64 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
15 |
12-13-2011 08:15 PM |
Catalytic Heater
elkay12 |
LP Gas, Piping, Tanks & Regulators |
15 |
10-29-2011 08:14 AM |
Duo-therm and furnace question...
NoMoSOBs |
13 |
10-21-2011 09:17 AM |
Need advice on furnace.
SilverRanger |
5 |
05-28-2011 03:47 PM |
Furnace and Hot water heater complete
Airdaddy |
3 |
02-02-2011 09:16 PM |
