Old 05-01-2007, 09:30 PM   #15
cammur's Avatar
Roseville , California
Golddigger,
Really enjoyed your vacation pictures, especially Alaska. A goal of mine someday but I dunno.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 05-06-2007, 06:54 AM   #16
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
Olympian 6100
Hi ,I just bought a Excella 29 footer,it has a Olympian 6100 Catalytic heater, I would like to hing the unit to swing into the kitchen area ,please let me know how your hing works Thanks.wbcci#3510
Originally Posted by golddigger
We had CampingWorld in Elkhart, IN, install an Olympian Wave 6 in our 31ft Classic last summer. The unit is great, but the installation was so-so. It fell off the wall while on the road:
Hamnqvist 2006 summer vacation: Day 28 -- From Coldfoot, AK to Deadhorse, AK
Works great although the kids are complaining a bit about it being too hot in the front of the trailer, while it not being that warm in the back. Allows you to extend your stay when you have no shore power. The cat heater does produce a bit of humidity as a by-product.
My installation has a copper line going through the floor and then a flex hose above. My plan is to install a hinge at some point. Using a stand is not that great of an idea if you have kids and pets, since the can/will tip over, with potentially bad consequences. I had mine put next to the door to reduce the risk my dane fries his butt.
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 04-08-2008, 10:58 PM   #17
1977 31' Sovereign
Prineville , Oregon
I've been using cats for years. First in campers and now in an AS. I have a wave 8 for AS. There are a few issues with cats that you should know. The combustion process generates water, lots of it! the humidity in an enclosed space can be a real pain. I've found a way to totally eliminate it though. Sorry I don't have pics, but I'll try to explain. I had a sheet metal guy fabricate a "chimney" for the heater. It is an aluminum box that is slightly larger than the top of the heater (about 1" wider and 1" deeper) and extends up the wall above the heater. The top of the box is closed and the bottom which sits even with the top of the heater is open. Hopefully you can visualize this. At the top you need to have a small port to the outside, like maybe a 1" tube running from the top of the box through the wall or ceiling. You don't want more than that because you will just lose heat. The box will get hot and radiate heat into the room so you want it away from where you might bump into it. You can also get aluminum gril material from any ace hardware and build a grill around the chimney. This set-up totally eliminates the moisture problem while still capturing nearly all of the heat! Cats are great IMO. They are very efficient, dead quite, and safe. Because they do not have fans, I use a 12V muffin fan, like the ones used in computers, but 12 volt, to circulate heat. The muffin fans use just milliamps of power and are very quiet and long lived. With the chimney fix and the muffin fan recirculater, the cats do a great job of heating for all but the most extreme conditions. I have camped in my camper at 7 below zero with the smallest cat you can buy.
My AS will have a mini wood burning stove and the cat back-up. No other furnace. I really enjoy the quiet.
David
DasAir is offline   Reply With Quote
Auxiliary catalytic heater bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-16-2006 03:41 PM
Catalytic Heater eracism Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-06-2003 07:15 PM
Catalytic Heaters - Who Wins? Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-18-2002 07:09 AM
Another Catalytic heater question Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-26-2002 10:57 AM
Olympian Catalytic Heater davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-26-2002 10:47 AM
