12-03-2018, 06:59 AM
#21
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you vent a catalytic heater so the moisture is no longer an issue, you loose the efficiency gain they provide.....
12-04-2018, 01:31 PM
#22
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Yeah, that's kind of true also in having to open a window or two while you use it, too. But it sure is nice to sit in front of that thing when you want a warm spot.
As for buying the guy out, not me. He makes them one-at-a-time. And I wondered how you could shut off the outside vents when you were not using the heater.
I really love my wave6. I think the heaters are not perfect, but certainly can add to your portfolio of things that make camping comfortable.
I recall an old-timer here - 2airishuman: He installed two Platinum Cats in his 34-footer and remarked on how "toasty" he felt.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
12-05-2018, 05:05 AM
#23
Dazed and Confused
Hillsburgh
, Ontario
Geez, whatever happened to "buy American". The guy makes a quality product from what I've been told.
As for shutting off the vents......The vents are tiny; less of an exit than a Suburban furnace.
A vented heating system is far safer and less hassle than a non vented one, especially one using propane; but you roll the dice however you want.
Cheers
Sidekick Tony
12-05-2018, 07:00 AM
#24
2006 31' Classic
Youngsville
, Louisiana
New vented heater
If I were to use the new vented heater linked above. I might be able to tap into a stack already inside the closet and not need to create a new outlet. I think it is the black tank vent. Would there be any reason to not mix the two “gases”
12-05-2018, 07:12 AM
#25
2002 25' Safari
Dewey
Mixing methane gas and a propane heater sounds like a recipe for disaster.
Richard
12-05-2018, 10:25 AM
#26
Dazed and Confused
Hillsburgh
, Ontario
Or a new heating source.[emoji23]
Cheers
Sidekick Tony
12-05-2018, 11:37 AM
#27
2007 22' International CCD
Corona
Or having a front row seat in the middle of a rapidly expanding fireball.
Besides, why make it easy for holding tank stench to get into the interior of the trailer even easier???
12-06-2018, 01:37 PM
#28
Ready-to-Travel
Walkerton
, Virginia
Actually, his design is better: He provides for fresh air intake as well as the exhaust line, so he is not burning inside air (which is a problem with the catalytics - they use your breathing oxygen.)
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Olympian Catalytic Heater
davidz71 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
2 |
02-19-2022 03:28 PM |
Therm'x catalytic heater
Dwight |
5 |
04-29-2012 08:28 PM |
Auxiliary catalytic heater
bhsl8 |
30 |
07-16-2006 03:41 PM |
Catalytic Heater
eracism |
1 |
01-06-2003 07:15 PM |
Another Catalytic heater question
Ken J |
4 |
10-26-2002 10:57 AM |
