Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-14-2002, 06:22 PM   #1
pebblepoint
pebblepoint's Avatar
Profile:
cat. heater's fuel supply-Inside??
My Overlander doesn't have a cat. heater, but I'm interested in buying one or two.
In a previous post, someone mentioned an 11 pound propane bottle being hooked to theirs. This sounds like they are using it indoors.
I just recently bought a Mr. Buddy heater (great unit) for my popup and it says to never put the auxillary propane tank indoors. I bought a hose to keep it outside. Problem there is that cold weather reduces the amount of propane that you can use from the bottle.
Do any of you have your bottle inside? Is this safe? Would a gas detector protect me?
Thanks from a newby.
don
Don, Kay and Max the Mastiff
'69 Overlander
'69 Avion Slide-In
'96 Starcraft Pop-up
You can never have too many campers
pebblepoint is offline   Reply With Quote
Old 12-15-2002, 07:25 AM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I am against putting the gas bottle inside. They tell you these things for a reason, and that is the leak potential. I would not worry about propane in cold weather. Propane starts to boil at -47 F. Butane, on the other hand, starts to boil off at 31 F. So as long as it is over -40 F, I would not worry about having the bottle outside. Millions of homes are heated in the Northern United States with propane tanks sitting outside.
My cat heater which is mounted on the credenza, next to the fridge, is tapped into the fridges line, with a "T". Most AS have the propane plumbing mounted on the underbelly skin, so it should not be a problem to tap into it for an aux heater.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 12-15-2002, 04:43 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
11 lb. bottle
Don,
I'm the one who had the earlier post on an 11 lb. bottle inside. I have used this combination for 16 yrs. in tents with the bottle outside most of the time and tried it last year in my 31' during the winter before installing my Wave 6. It does have the potential for disaster IF you do not check the connections carefully for leaks. I have a 12 ft. hose and run the bottle as far away as I can. I advise you to look at tapping into your existing gas system and running a quick disconnect through the floor or bulkhead if you are looking for a portable unit hooked to a larger bottle source. Go to www.rvsolarelectric.com for a description of this setup.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-15-2002, 04:49 PM   #4
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Thumbs up Propane at low temperatures
I heated my house in the Colorado mountains with propane and it worked just fine at 20 below zero. That should be a whole lot colder than you ever use your A/S.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 12-15-2002, 05:02 PM   #5
davidz71
davidz71's Avatar
During all those years of camping in cold weather, the coldest it ever got was around 14 degrees. I had no trouble with the propane catalytic. 10 yrs. ago I bought a GAZ backpacking lantern which uses a propane/butane combination and had trouble lighting it in freezing weather. I remember reading that propane works better in colder weather than butane but am not sure of the source.
Craig
AIR #0078
3.73 rear end
cat door Cat The Pet Forum 2 11-09-2003 11:21 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 05:35 PM
Trip report (fuel filter issues) PeterH-79MH Airstream Motorhome Forums 10 08-01-2003 06:57 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
fuel pressure PeterH-79MH Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 09:40 PM
test
