Old 05-15-2010, 09:05 PM   #1
1973 23' Safari
Crestwood , Kentucky
Carrier AC Unit Drain Hole
I am in the process of installing a new Carrier 13.5 "non" low profile AC unit in my 1973 Safari. I have seen threads on the forum that you can drill a hole in the pan of the sling wheel and use the existing drain tube. Does anyone have pictures of where they drilled this hole? I thought I actually saw a video of someone doing this on the internet but I cant find it again or maybe I was hopefully wishing. If anyone could point me to a picture of how this was drilled I would greatly appreciate it.
jhonken is offline   Reply With Quote
Old 05-16-2010, 01:04 AM   #2
The hole is drilled at the bottom of the collector pan.
That's the easy part.
You then must install a connector, so that you can attach the drain hose. Not easily done because of the lack of space.
However, I would suggest you leave it alone, as very rarely will any water overflow onto the shell.
Old 08-22-2010, 08:33 AM   #3
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
What happens if there is no collector pan to drill a hole into under the sling wheel? Does anyone know where to get one?
GREENovaters is offline   Reply With Quote
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
Drain adapter for LoPro Carrier A/C thombrad Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-16-2007 10:56 AM
How to Drain A Carrier ? AndyS Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-16-2006 06:21 PM
Found a great place to get a new Carrier A/C unit! Anon Furnaces, Heaters, Fireplaces & Air Conditioning 0 02-25-2005 01:06 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
