Old 07-15-2010, 06:15 PM   #1
Wooden Rivet's Avatar
1956 26' Cruiser Overlander
McLeod , Texas
Carrier AC help please
Just installed a new 13,500 Carrier standard AC. It is leaking water onto the floor from excessive condensation. It is pooling on the top of the inside unit, and being blown out by the fan. Anyone have any suggestions?
Thanks in advance,
Tom
Wooden Rivet is offline   Reply With Quote
Old 07-15-2010, 06:17 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Did this unit come with a drain line attachment?
Richard
Old 07-15-2010, 06:25 PM   #3
McLeod , Texas
It just so happens that I decided to buy a Carrier because it was one that could be hooked up to the drain hose readily. Guess I didn't do enough research because the standard height model is the only one that can't be hooked onto the hose. It is draining heavily out onto the roof, but is still leaking on the inside.
Tom
Old 07-15-2010, 06:25 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
That unit should have the 'slinger wheel' that is supposed to blow the condensate back across the condenser to help cool it and to get rid of the liquid.
Remove the shroud and be sure that the channels are not blocked and that the drain (if you have one) is properly connected to the drain hose. You should not be getting any liquid inside the trailer.
Also be sure that your bolts are tightened so that the A/C gasket has been compressed by 50% to properly seal to the roof.
Old 07-15-2010, 06:29 PM   #5
McLeod , Texas
This unit can't be hooked up to the hose says Carrier tech.
Old 07-15-2010, 06:30 PM   #6
McLeod , Texas
Gasket compressed well.
Old 07-15-2010, 06:32 PM   #7
McLeod , Texas
Killer weather here today 100 degrees and 100 % humidity. Maybe it's just too much to drain away.
Old 07-15-2010, 06:37 PM   #8
lewster's Avatar
If the water drains out both sides of the unit, you might be able to modify it to accept the Dometic auxiliary drain kit, part # 3107688.016.
These kits are used on just about every Duotherm installation that requires the use of an internal drain hose like Airstreams and most other quality RVs have.
The kit consists of 2 catch cups that are attached directly beneath the drains. These cups have molded-in nipples which connect to the supplied tubing. The water drains from the tubing via a 'T' fitting that connects to the interior drain hose. An extra gasket is also included to raise the unit slightly to provide clearance for the drain cups.
You might check it out!
They DO work well!!
Old 07-15-2010, 08:21 PM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
is this the one....?
Maybe this is the one Lew is mentioning...
Old 07-16-2010, 05:25 AM   #10
lewster's Avatar
Nope!
That's the full drain pan.
This drip kit had 2 small molded plastic cups with flat bottoms that screw into the base pan of the unit directly below the drain holes. They are maybe 2-1/2" X 3-1/2" and 3/4" deep. Comes with the extra gasket and required hoses and fittings.
Old 07-16-2010, 05:33 AM   #11
McLeod , Texas
Thanks everyone for your help. Guess I will get the auxilliary drain kit and give it a try. I'm still not sure that will correct my problem of water leaking on the floor though, but I would prefer draining through the hose.
Tom
Old 07-16-2010, 09:28 AM   #12
Dan@LED4RV's Avatar
Denton , North Carolina
Originally Posted by Wooden Rivet View Post
......... Guess I will get the auxilliary drain kit and give it a try. .......
Tom
I have tried to get a drian kits to work with one of those Carriers but it won't work. The Carrier will channel the water to the middle to be directed to the fan so it could be sprayed out the back. ( that thing has to be perfectly level which may be where the water is coming from ) The Briskair pulls the water over to the side.
I know for a fact. your going to want to take that AC back if you can. Been here, done this.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 07-16-2010, 10:26 AM   #13
airstream66's Avatar
1966 30' Sovereign
Bethany , Illinois
Images: 22
Don't mean to sound stupid, but make sure there are no holes under the A/C unit. Like missing rivets. SOB dealer put mine on and didn't fill them in.
Cory, Angie, and 'Lucy'
1966 Sovereign International
2003 Black Chevy Silverado w/q-steer
airstream66 is offline   Reply With Quote
Need Help New Carrier won't fit. mikesplace 1970-79 Tradewind 4 07-27-2009 09:43 PM
new carrier a/c evelitalian Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-21-2008 04:26 AM
New Carrier HP/AC 2toomany Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-19-2006 08:09 PM
Carrier V A/C 53flyingcloud Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-27-2005 08:52 PM
New Carrier A/C Igor68 Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-29-2004 10:43 PM
