Old 05-03-2007, 04:39 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Carrier AC - Fan Speed
I have a Carrier 15,000 BTU AC that I installed on my 1976 A/S last year. Works and cools very well. My only complaint is the fan speed, high and higher and not very quite. A lower quieter fan speed would be nice. Is there any way to retrofit a lower fan speed switch?
Don
adonh is offline   Reply With Quote
Old 05-03-2007, 06:35 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Don
Don,
You probably could, but you probably shouldn't!
Every RV roof A/C is designed to operate at a minimun CFM (cubic feet per minute) of cold air discharge. If this requirement isn't met, the result is usually evaporator ice-up. This happens from blocked ducts, intake air mixing with cool discharge air, and a number of other variables .
I'm certain that Carrier (and all the others) take this effect into account when they design their units.
Old 05-04-2007, 07:19 AM   #3
adonh's Avatar
1976 31' Sovereign
That's what I thought. To bad, this is the only thing that prevents the carrier from be a great AC unit. Even my old Armstrong before it bit the dust had a good low speed fan and from what I understand the Dometic Penguin is very quite and has a low speed fan.
Don
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
