Old 03-22-2016, 01:45 PM   #1
1982 27' Excella
Huntsville , Texas
Question Carrier AC Drain
I have an 82 Excella with a carrier V HC AC. I do not believe that the AC is original to the trailer. The trailer has a drain hose coming out the bottom. The AC manual says the the AC drain should be cleaned yearly. When I removed the cover on the AC I do not see any connection for a hose. does anyone know if I am correct in assuming that the original AC had a drain to the hose but the replacement AC does not have a hose drain -- ie it just drains water to the roof?
GMarugg is offline   Reply With Quote
Carrier Normal Profile - Add Drain Line vhariable Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-01-2011 01:51 PM
Carrier AC Unit Drain Hole jhonken Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-22-2010 08:33 AM
Drain adapter for LoPro Carrier A/C thombrad Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-16-2007 10:56 AM
How to Drain A Carrier ? AndyS Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-16-2006 06:21 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
