Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-14-2007, 11:36 AM   #1
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Carrier A/C std vs low profile
I am seeking opinions on the carrier A/C - the low profile is $170 more than the standard and does not have the slinger technology - the low profile is 7.5" whereas standard is 13" - as a comparison the penguin is 10". I'm thinking about just getting the standard
Ken J.
1958 Overlander
Ken J is offline   Reply With Quote
Old 06-14-2007, 05:01 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Ken J.
The Carrier low profile, is by far, the best.
No drain pan is required.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-14-2007, 05:33 PM   #3
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
check here: New Moon Roof
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-14-2007, 06:07 PM   #4
Coloradobus
Profile:
Ken J,
We installed a low profile Carrier on the GT for Salem last year. 15,000btu's of cooling. Great!!!! at temperatures in the 100's. The GT was a cooool 72 when outside was 104!!
We will be installing a low profile on the '79 Trade Wind. One thing we will do different is, adding the heat strip optioin to the TW's soon to be new A/C
OUr B Van and Bambi Quick Silver have to Penguin. It is relatively low as well. Our Caravanner came to us with the high profile Carrier on it. Since we are going to leave this trailer mostly original, we may take the 13 inch tall A/C unit off. The P.O put it on 2 years ago.
Jim and Chris
WBCCI #5812
Denver Unit 024
'51 15 panel 22ft. Flying Cloud
'59 Caravanner
'67 Globe Trotter
'79 Trade Wind Int'l
'97 B-190 B-Van
'06 Bambi Quick Silver (2nd yr ownership, insufficient axle,, but for 2 grand Airstream said will beef up axle)
'00 S.O.B. Motorhome
Coloradobus is offline   Reply With Quote
Old 06-14-2007, 07:28 PM   #5
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Cool
We love our Penguin, but if the low profile is better, why not just do it once?
With a 26 footer, go with the 15k unit.....you won't be sorry. Best thing I ever did, particularly if you go in hot areas.
Old 06-15-2007, 07:43 AM   #6
Ken J
Low profile it is!
Thanks as always for the help.
Ken
1958 Overlander
Old 08-02-2007, 03:31 PM   #7
tlavergne
tlavergne's Avatar
Profile:  1978 29' Ambassador
Kenton , Ohio
Andy, Why is no drain pan required? I think I need to replace my original Armstrong on my 1978 Ambassador. The AC keeps tripping the trailer breaker after about a half an hour in 90 degree temps. The Carrier Low Profile 15,000 with a heat strip sounds like the best option.
Thanks.
Tom
tlavergne is offline   Reply With Quote
Old 08-02-2007, 03:57 PM   #8
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Carrier Questions
Thanks.
Tom
Is the Carrier low profile available with a heat pump. I have emailed Carrier, but they have not answered. Not impressed. I am also interested in the drain pan, Andy.
Vaughan
Old 08-02-2007, 03:57 PM   #9
Commercial Vendor
Thanks.
Tom
A drain pan is built into the base.
Simply hook up thr drain hose to the drain pan.
However, installation can be a problem if you have a center bath.
Your present AC can be tripping the breaker for several reasons.
If your using an extension cord, it must be of adequate rating. The rating depends on the length of the cord.
The line voltage could be low to start with.
The freon level could be low.
The compressor could be on it's last legs.
Inlandrv.com
800-8777311
Old 08-02-2007, 04:03 PM   #10
Commercial Vendor
Vaughan
Carrier does not have a 15,000 BTU heat pump AC.
I don't recommend a heat pump for several reason.
1. The compressor runs in the heat mode.
2. That shortens the life of the compreesor considerable.
3. If you need that much heat, then run the furnace.
4. Running the furnace, when it's very cold or freezing, circulates hot air around the water pipes, which keeps them from freezing.
Inlandrv.com
800-8777311
Old 08-02-2007, 04:12 PM   #11
vswingfield
1967 24' Tradewind
Images: 32
Thanks Andy,
I would definately run the furnace under 40 degrees, anyway. Much of our winters here in Arkansas are above that. I was considering it given the cost of propane anymore. I also supplement with a tall electric heater that stands well above the carpet.
Vaughan
Old 08-02-2007, 04:19 PM   #12
Overlander & Sea
Overlander & Sea's Avatar
Profile:  1961 26' Overlander
Gulfport , Mississippi
Images: 12
I just ordered a Carrier low profile, 15,000btu's with the heat strips for our '61 Overlander. For the size of the AS, looks, reviews of the unit, etc., I thought this was the way to go. Anyone need an old orginal(?), metal case unit that works?
Rick, JJ, Tommy, and Will
1961 26' Overlander International Land Yacht
WBCCI #9275
Overlander & Sea is offline   Reply With Quote
Old 08-02-2007, 04:23 PM   #13
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Oh, so tempting - And I could drive over and pick it up........
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 08-02-2007, 04:26 PM   #14
Overlander & Sea
Images: 12
Mike, it's yours. Just PM me.
WBCCI #9275
Carrier low profile A/C questions JKWoodrow Classic Motorhomes 7 04-06-2007 10:38 PM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 03:14 AM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-09-2005 03:53 PM
Thetford Toilet Repair??? Galaxy Low Profile 1985air345 Sinks, Showers & Toilets 8 12-10-2003 07:44 AM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 08:52 PM
test
