Good afternoon everyone... On the subject of heat strips, we put one in our other Argosy when we put the new A/C in... didn't like it and would not waste our money again on one.. just our opinion
Sorry.... but, you're in Canada... that would be like lighting a match with the hope of taking the chill off -10 degrees...
It works like the dickens with most of our winters... Damn! At the rate we're using propane for cooking and the furnace, we have to refill the tanks about every 6+ months!
. Bill & Kim's Marvelous Adventure with Catahoula Charlie
30' Classic
F250 Diesel
AIR 9218
I've found the heat strip sort of useless also. Problem is that it takes to long to provide any meaningful warmth and it can't be controlled (at least with the A/C units I have owned), by the thermostat. I end up turning it off, then getting cool and turning it on again.
While there is a price to pay for a heat pump, and yes there is some wear and tear on the compressor due to it running more, it does save propane, it runs off the thermostat, and for all intents can push a decent amount of heat out (far more than the heat strip). We use the heat pump in the spring and fall unless the temps fall below 45 or so.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Worked just peachy at 38. Fleece pull over and sweats, our friend Jack D. and a game of cards with vintage radio shows on CD... 32, it sucked, furnace time and man-o-man, soooo fine!
30' Classic
F250 Diesel
AIR 9218
Hi Bill,
Sounds like a nice evening. I have an old Admiral tube radio in storage since I moved into the Trade Wind a few years ago, now in the Excella. Last time I turned it on was about 2 in the morning and I got Kukla, Fran, and Ollie. Old radio, old shows.
Sounds like a nice evening. I have an old Admiral tube radio in storage since I moved into the Trade Wind a few years ago, now in the Excella. Last time I turned it on was about 2 in the morning and I got Kukla, Fran, and Ollie. Old radio, old shows. Vaughan
I know what you mean, Vaughan. Something nice about an Airstream and those oldies...
Wish the heat strips/pumps worked better down to about 25-30 so as to save on propane. For the most part, they work well down here. Can anyone tell me if the capacity of the strip/pump corresponds to the size of the unit - 13,500 vs. 15K? Or is the heating ability the same on both. We're still going back & forth as to upgrading to a larger A/C unit for our 30'.
30' Classic
F250 Diesel
AIR 9218
As far as heat strips, I’m pretty sure one size fits all. As far as AC size goes, just as soon as I can afford it, a new 15,000 Btu Carrier is going on my 34’ Excella. My experience with Hill Country summers suggests that it would not be a mistake for you, either.
I’m thinking a heat pump for those above 40 nights with a heat strip bottom to help on the colder nights. The pump is related to the size of the AC.
I have a tower electric heater that stands above the carper, and I rarely ran the furnace this winter between it and the heat strip. It was unusually cold too. Your comments on this thread about the extra 50 cfm may help in my decision.
Jaxon,
Heat strips are typically less than 500 watts, so they don't really have the capacity to create a lot of heat but they will take the chill off by several degrees.
