Old 02-11-2011, 05:57 PM   #1
1977 Argosy Minuet 6.0 Metre
deland , Florida
Carrier 13,500 ac unit for a 66 safari
hey guys ive tested and tested and found my factory ac unit is trashed so im looking for a new one. i know someone with a carrier 13,500 btu ac unit in like new condition that he wants a couple hundred bucks for. is it a big deal to pull out the factory roof unit and install one of these? does it fit good w our curved ceilings? and will 13,500 be enough for a 22 foot safari? keep in mind i do live in fl. i dont have any pictures of the unit but here is one just like it on ebay but a 15,000 instead of a 13,500
NEW CARRIER 15k BTU RV A/C AIR CONDITIONER HEAT PUMP - eBay (item 130391804051 end time Mar-11-11 12:52:52 PST)
386kustoms is offline   Reply With Quote
Old 02-12-2011, 07:50 AM   #2
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
We have the 13.5 Carrier in our 22' Safari (not the heat pump version) and last summer in high 90's it was more than sufficient.
Ahab is offline   Reply With Quote
Old 02-12-2011, 08:12 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I put a Carrier on my 66 Caravel. The 13500 did a great job...even here in Texas. The installation is easy once you get it up top. The curved roof was no problem either...the inside unit fit well.
Old 02-12-2011, 08:18 AM   #4
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Could be bigger deal
Than you think. If your 66 has the original AC then there will need to be some modifications necessary to install the 'new' unit. You will need to cut a 14" x 14" open as the original unit only had some smaller holes for pipes to pass thru. In addition to the larger opening it will require some structural bracing around the new opening to support the new unit. If you need details you can do a search to see what others have done. Also, I'm not sure if your new AC would have a drain pan for condensation runoff so you may want to check.
SilverHoot is offline   Reply With Quote
Old 02-12-2011, 06:36 PM   #5
deland , Florida
i relized about the 14x14 hole that needs to be trimed. i guess i was more worried about the curvature of our trailers and making sure there will be no leaks. and if the unit will cool enough for our safari.
also from what i read they seem to be a good reliable company for ac. has anyone had any problems with theres?
Old 02-12-2011, 06:50 PM   #6
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
On my 15k heat pump, the electric strip does not work.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 02-12-2011, 08:24 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You mean besides the fact that they are no longer in business as an RV a/c company?
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
Want to get my 1964 Safari ready for travel Safari Bob 1964 Safari 3 02-24-2011 07:32 AM
NM Unit and 4CU Jemez Mountains Joint Rally LHall WBCCI Rallies & Events 0 01-05-2011 07:27 PM
