Old 09-15-2004, 10:58 AM   #1
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Caravel questions
Since I live in Texas, I'm contemplating adding a Duo-Therm low profile A/C unit to the Caravel. There is a piece of black romex cable that is looped into the roof vent opening. Is this for an A/C unit? Would there be a drain line hidden somewhere too? Also, if I add and A/C unit, how feasible would it be to relocate the roof vent forward of the A/C? Also, I need a refrigerator (it doesn't have one), what is recommended to go back in the hole? Thanks.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 09-15-2004, 11:26 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Caravel questions
Greetings 62 Overlander!
Unless the Caravel is an exception to the rule, I would be very surprised to learn that an exisiting vent opening is the place where the factory intended for the air conditioner to be installed. According to my notes, the '67 should be pre-wired for air conditioning as you have already discovered - - I also belive that it may have a built-in through the wall condesate drain pre-installed as well. I suspect that the intended location for the air conditioner may actually be to the rear of the existing vent opening - - an Airstream dealer or Airstream technical support at the factory should be able to provide you with the measurement from the front main bow for the air conditioner install. While it is over a decade newer, my Minuet's air conditioner installation location was to the rear of the existing vent opening, but if my memory is correct a Caravel with a factory air conditioner had its air conditioner in a similar location.
For the refrigerator, you may find that an exact replacement isn't available - - there wasn't for my '64 Overlander. You might try checking the dimensions of the current Dometic RV refrigerators at:
Dometic RV Refrigerator Replacement Model Dimensions
Good luck with your projects!
Kevin
Kevin D. Allen
AIR #827
Old 09-15-2004, 11:35 AM   #3
1954 25' Cruiser
Paradise , Texas
thanks Kevin - The Dometic site did show one similar in size, so that's good news. Concerning the vent, I was surprised too to see that wire looped in there. The vent though is pretty far to the rear of the trailer. It is 10.5 inches forward of the rear main bow. I didn't think of trying Airstream. I'll give that a shot.
Just when you get ahead on one project, along comes another.
Paul Mayeux
AirForums #1565
WBCCI #7162
caravel
Another happy Caravel owner rluhr 1966-68 Caravel 110 07-04-2007 03:04 PM
11 days in a Caravel! Stefrobrts On The Road... 14 09-17-2004 07:14 AM
Picking Up 1961 Caravel kayelm On The Road... 17 08-28-2004 12:49 PM
