Old 05-17-2011, 01:53 PM   #1
1968 24' Tradewind
Sanford , North Carolina
Capacitor question
I have not been able to find a capacitor that is like the one on my unit. I asked an air conditioner guy and he said that the new capacitors have 3 prongs instead of 2. Has anyone replaced a 2 prong with a 3 prong?
yowproject is offline   Reply With Quote
Old 05-17-2011, 02:50 PM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
What is the value/voltage of your capacitor?
TX-16
Dave Park is offline   Reply With Quote
Old 05-17-2011, 05:41 PM   #3
1968 24' Tradewind
On the replacement parts list it is 370volt 30mfd, the new one with 3 'prongs' is 370volt 35+5mfd. I'm trying to help my husband decide if he use the new one!
Old 05-19-2011, 10:06 PM   #4
Dave Park's Avatar
2005 22' Safari
Like this?
TX-16
Old 05-19-2011, 10:51 PM   #5
Hueytownalss's Avatar
Hueytown , Alabama
I replaced capacitors in the 12 volt converter/charger in my 78 silver streak recently. A I found an exact replacement capacitor at tedss.com. They have about every capacitor made and they ship quickly.
Hueytownalss is offline   Reply With Quote
Old 05-19-2011, 11:00 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
Those caps w/ three prongs are just two caps in one w/ a common ground. If one is close to the right size (in microfarads), it will work. Just use the right prongs - they will be labeled.
Typical tolerances on capacitors are quite loose; 35 vs 30 isn't a lot of difference here.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-20-2011, 12:52 PM   #7
Hueytown , Alabama
If you have the old one, you probably can match it up here. Capacitors
They do have 2 pronged ones.
Old 05-20-2011, 01:42 PM   #8
1968 24' Tradewind
thanks!
