Old 08-18-2010, 10:47 PM   #1
2009 25' FB Flying Cloud
manitou springs , Colorado
Can't get duotherm to acknowledge furnace...
2009 Flying Cloud, used once, bought from original owner (TX RV dealership owner). Anyhow, the duotherm lcd thermastat won't recognize furnace as operable mode. Checked furnace from outside, it has never been used and is switched to "reset" (other choice, "off"). Called service from where I purcahsed (I am in CO). Turns out they replaced entire AC unit as it was blowing fuses and they could not figure out why. Service guy tells me there is a relay to furnace through AC unit and maybe they forgot to connect it??? When I took off interior cover found two yellow wires in main wire harness not hooked to anything and a pair of thin white wires that came together into a plastic female connector. No matching male connector to be found.
Does the furnace wire through the AC unit make sense? what else could be wrong? it is starting to get cold up here at 7000ft! Please help, and thank you!
movin-in is offline   Reply With Quote
Old 08-18-2010, 11:58 PM   #2
_
lots of options here...
the thermostat may need to be setup/linked to the furnace
(this is explained in the thermo booklet and on line...
perhaps the dealer/service guy was referring to the DIP SWITCHES...
there are DIP switches on the AC
that need to be properly flipped for full function at the thermostat.
each DIP recognizes stuff ((furance, ac, heat pump, thermostat and so on))
the DIPs are outside, UP top, under the shroud
(location and SEQUENCE is covered in the a/s INSTALL manual)...
loose wires in the ac cover? that's not good.
take a few PHOTOS and post them or get out the a/s INSTALL instructions and read...
IF the dealer didn't include those instructions, they are ONLINE for reading.
cheers
2air'
Old 08-19-2010, 04:14 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by movin-in View Post
... the duotherm lcd thermastat won't recognize furnace as operable mode. Checked furnace from outside, it has never been used and is switched to "reset" (other choice, "off")....I took off interior cover found two yellow wires in main wire harness not hooked to anything and a pair of thin white wires that came together into a plastic female connector. No matching male connector to be found.
The two yellow lines go to a load shed to prevent two AC's coming on at the same time if you are only on a 35 amp service. You don't need to be concerned with these - they are mostly for MoHo use.
The two white wires are for a remote sensor cable and are probably wired correctly.
There are two blue wires that should come from the control board to the furnace thermostat wiring.
Unless you have a heat strip, all of the dip switches should probably be in the "off" position.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-19-2010, 04:46 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
http://bryantrv.com/docs2/docs/acservice.pdf
http://bryantrv.com/docs2/docs/ccc5.pdf
http://bryantrv.com/docs2/docs/ccc4.pdf
If you have the 5-button thermostat then there is a DIP switch that indicates the presence of a furnace. This DIP switch must be turned on and the thermostat reset.
4-button thermostats are different and generally assume that there is always a furnace.
Old 08-19-2010, 07:28 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
I Disagree
...If you have the 5-button thermostat then there is a DIP switch that indicates the presence of a furnace. This DIP switch must be turned on and the thermostat reset...
The first dip switch on SOME models control an integrated heat strip - not a furnace....if so installed (internal heat strip) this first dip switch must be switched "on".
From the AC Service PDF above...
"One Rooftop Air Conditioner plus One Gas Furnace
To configure one rooftop air conditioner plus one gas furnace,
all Dip switches are .OFF. and the freeze control is
plugged into the proper connector (blue). Two thermostat
wires from the furnace, AC power, DC power and communication
line are properly connected to the air conditioner control box."
or, if the unit is a heat pump...
"One Rooftop Heat Pump Plus One Gas Furnace
To configure one rooftop heat pump plus one gas furnace,
all Dip switches are OFF. The freeze control is NOT used.
The blue connector must stay open (P5). The ambient sensor is plugged into the proper connector (red). Two thermostat wires from the furnace, AC power, DC power and communication line are properly connected to the heat pump electronic control box."
Dennis
WBCCI # 1113
AirForums #1737
Duotherm thermostat crispyboy Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-31-2008 07:50 AM
ordering new penguin duotherm twiggy137 Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-31-2008 07:25 PM
Duotherm A/C support bracket? rphdiego Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-21-2008 05:32 AM
1969 GT DuoTherm dbaur Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-08-2006 10:50 PM
need gasket for original DuoTherm furnace KHarris Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-01-2006 04:33 AM
