Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 08-19-2006, 08:44 PM   #1
tobynamy
tobynamy's Avatar
Profile:  1962 26' Overlander
pine bluff , Arkansas
can't find leak
I have a 1962 overlander that has developed a leak and I cant seem to find it. The water is dripping out from behind the road side back tire under the hot water heater, but inside is completely dry. Is there any way to find leak without pulling belly pan, or has anyone had this same problem. If it is running from front were would it be coming from? Could it be coming from the air conditioner through the walls? I'm lost. Any help would be Appreciated.
Toby Allen
1962 26ft. Overlander
tobynamy is offline   Reply With Quote
Old 08-19-2006, 08:52 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
When is it leaking? When it rains? When you run the AC? If it is the fresh water system the pump would cycle on and off by itself. Does that happen?
Richard
Charter Member Four Corners Unit
Old 08-19-2006, 08:55 PM   #3
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
the airconditioner drain line comes out inside the wheel well, up near the top. The water could be adhering to the wall and dripping off the back edge, right where it would look like it was "under the water heater."
If your water pump isn't cycling on and off by itself occasionally, you don't have a system leak (providing you're on the pump, not shore water!).
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Zeppelinium is online now   Reply With Quote
Old 08-19-2006, 09:07 PM   #4
tobynamy
tobynamy's Avatar
I have unhooked all water and turned off air and will turn each sytem on one at a time time to try and find it. I don't use pump on water from hose so i don't know if it is fresh, a/c condensation, gray( as drain from sink goes into floor right beside hot water heater), or hot water heater. my air conditioner runs water to the outside but I thought it could be leaking in at the top, it just runs doun the side of the trailer.
Toby Allen
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 09:39 PM
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 09-14-2002 12:42 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 07:28 AM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 07:17 AM
test
