Old 12-13-2007, 09:39 AM   #1
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Candle Heater
Has anyone tried one of these "Kandle Heeter" contraptions? I'm thinking of trying it out, because I'm a sucker for low-tech solutions. It might be good while boondocking in cold temps, and you want to conserve onboard propane.
RV News Magazine | The Voice of the RV Industry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 12-13-2007, 09:49 AM   #2
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
That is pretty darn clever!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 12-13-2007, 09:52 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
A candle (plus your body heat) will significantly warm snow cave, but that's a very small space. I can't see it heating an Airstream. That contraption can't make it any warmer than a candle alone will and I suspect a lot of folks have lit candles in their AS and didn't find themselves shutting off the furnace.
Old 12-13-2007, 10:16 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Very neat. While I do agree the device can't make heat, it could certainly concentrate the heat made by the candle, thereby making a nice warm spot.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 12-13-2007, 12:00 PM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I camped with a 70 year old gentleman once and he had a terra cotta pot turned upside down on his stove. I asked what he was doing with it and he said he heats it up from the burner slowly and just before going to bed, he would turn off his burner. The pot would give off the radiant heat it had absorbed and keep his camper warm for hours. I plan on trying this when camping over new year's. If a candle will take the edge off, then this would really give off some heat.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-13-2007, 12:19 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I've heard this one before too.
FF
Let us know how it works out.
Paula
Old 12-13-2007, 01:18 PM   #7
Alumatube's Avatar
New Holland , Ohio
Well, you know SoldierMedic smokes meat in a terra cotta flowerpot and it does AWESOMELY!!!
I think that info is in the portable grill thread...
Susan
Old 12-13-2007, 02:35 PM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Flower Pot RV heater
You would be surprised. Get yourself a NEW clay pot from Home Depot. I say new, as it will contain almost no moisture. A single 6" pot will do. Turn a burner on as low as you can get it to stay on. Place the pot, open end down, over the flame. The pot will get very warm and radiate a substantial amount of heat. Much more than the flame alone. Just like a catalitic heater does much better than the flame heating it would do by itself.
Old 12-13-2007, 03:13 PM   #9
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
That is the coolest thing! Well, I am going to Lowes tomorrow to see if I can find me a pot and I will let you know how it works!
Tammy
Silver Threads is offline   Reply With Quote
Old 12-13-2007, 04:09 PM   #10
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Has anyone looked into soapstone? It is better than terra cotta for storing and radiating heat. I know that they make pots and cooking boards that can be heated the same way on the stove or campfire and gives off heat for hours.
Soapstone
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 12-13-2007, 05:18 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
A 6" terra cotta pot at Home Depot is $1.28.
Old 12-13-2007, 05:54 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Just don't forget the CO hazard. It wouldn't be too much fun to leave the pots on the stove with the burner on, fall asleep and wake up dead.
Old 12-13-2007, 06:07 PM   #13
2007 25' Safari FB SE
Truckee , California
The Canadian Mounties devised a candle heater for use in their tents when they were out in the Boondocks during the winter. It's the same concept .
Take a one gallon empty metal container (paint thinner,coleman fuel,etc) cut a 4" x 4" square out in roughly the center(front side), to place candle inside. drill 4 holes spaced equally apart in front ,near bottom of can. Leave lid off place candle inside and light. Works perfect in tent but not enough heat for camper or trailer. candle heater above also would not be enough heat.
fred
flyfishfred is offline   Reply With Quote
Old 12-13-2007, 06:51 PM   #14
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
BTU's are the usual measure of total heat quanity. BTU's per hour is the usaual way you rate a furnace or any other heat source. It is also the way you measure the rate of heat lost from the trailer at a specific outside temperature. Our furnaces are usually rated to generate about 20,000 to 40,000 BTU's per hour. An individual propane stove burner is about 8,000 BTU's per hour. The catalytic heater or the stove burner is more efficient at raising the internal temperature of the trailer than the furnace because the furnace sucks in al ot of cold air to flow thru the burner to be heated by the fire and then exhausts that hot air outside after giving up some of its heat thru the heat exhanger. I dare you to hold your hand in the exhaust from our furnaces for very long. All this heat in the exhaust is wasted and does not heat the trailer. The BTU's from a candle are tiny by comparison to amount of heat per generated by our furnaces or heaters. An electric heater that uses 1,500 watts (which can be run off a 15 amp 110 volt circuit) will keep a trailer warm down to an outdoor temperature of 30 F, if the wind is not blowing too hard. Putting a can around a candle does not generate anymore heat than the original candle. Putting a clay pot on the stove does not generate any more heat than the burner id putting out. The pot simply stores some of the energy to be disapated later. If it were not for the steam causing problems of condensation, water is one of the best medias for storing energy. If you heated the water to less than its boiling temperature and kept a fairly tight lid on it, that would work better than any clay or soapstone pot. They sell oil containing electrical heaters that might work pretty well at slowly releasing heat to the trailer after being plugged in during the evening and then unplugged while you sleep. Those 12 volt mattress heaters or electric blankets are also are very effective at keeping just you warm when you go to bed and you are not concerned about heating the whole trailer. In real cold weather, not using the furnace means the tanks are not heated and you could cause major damage.
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
heater help trea LP Gas, Piping, Tanks & Regulators 7 10-21-2006 02:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
under the heater Phaedrus Repairing/Replacing Floor &/or Frame 0 05-09-2003 11:38 PM
