Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-30-2007, 06:18 AM   #1
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Can the circuitry handle an electric space heater
Hi,
I just bought a 1500 watt (max) oil filled radiator type heater to augment my furnace. I think this will work great with the register from the furnace blowing over the fins of the heater. My question is whether the circuitry of my 1979 31' International can can this 12.5 amp load let's say at a continuous duty.
wacnstac is offline   Reply With Quote
Old 03-30-2007, 07:14 AM   #2
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Originally Posted by wacnstac
Hi,
I use one in mine when hooked to shore power, never had an issue.
have on occasion, run an extension cord form "outside" to power it when I found the voltage to be low (@ or below 104)
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
Last edited by Pahaska; 03-30-2007 at 08:33 AM. Reason: Please use standard font and size from now on.
balrgn is offline   Reply With Quote
Old 03-30-2007, 09:19 AM   #3
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
In a word NO. You can plug it in and it will run however depending on which circuit you are using within the trailer you may just over heat that wire or the combined load of all the circuits in the trailer. Assuming you are using your refigerator on electric and your convertor you would overload either of the circuits if you plugged in the heater.
If you question these comments just plug your heater in , for 1/2 hour or so, while other normal electrical items are operating then go feel the shore core at the receptacl or open the panel box and feel the wire as they come out of the breakers.
Unless I turn my refigerator to gas, and use that circuit, I limit any heater in the trailer to 750 watts ans use a heavier blanket.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 03-30-2007, 09:25 AM   #4
wacnstac
Images: 41
The only other electrical item of significance that would be running is the convertor. My fridge is run on propane only this would be for night use, so not a whole lot else going on in the trailer except running the furnace at the same time.
Using the circuit for the fridge is a good idea, assuming that it is the only thing on the circuit, but plugging the heater into this circuit would be tough since the outlet is on the outside in the fridge compartment.
Old 03-30-2007, 10:01 AM   #5
wacnstac
Images: 41
After reviewing my circuit diagram it looks like it would be fine to plug the 1500W heater into appliance circuit which powers the fridge (not used), microwave, not being used, and has an outlet in the dining area. This circuit does not have the univolt on it and is rated for 20A. Should be more than enough for the 1500W.
Old 03-30-2007, 10:27 AM   #6
Pecos Pete
Profile:  2007 34' Classic
Pecos , New Mexico
I use a 1500 watt Vornado heater all the time without a problem. I plug it into the kitchen appliance outlet or the outlet under the dinette. I usually turn it off when using the microwave - has never blown the breaker, but it is just a thing I have.
Pecos Pete is offline   Reply With Quote
Old 03-30-2007, 03:40 PM   #7
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
I question these comments
If you question these comments ...
A wire will not overheat if the Airstream's circuit breakers are in good order. A wire can safely feel warm to the touch even in a new home or trailer and still function fine & meet code. My 1500 watt heater cord gets warm to the touch, but the cord is only 16 gauge wire as opposed to the larger 12 gauge wire used to wire 120 vac outlets. I do not consider this an issue.
To all vintage owners: If in doubt, replace the breakers.
To everyone: If the load is too much, the breaker will trip long before the Airstream's internal wiring approaches anywhere near an unsafe temperature.
If the combined load gets too high, the main breaker will trip. If that should happen, turn appliances off accordingly. But an RV refrigerator does not pull that much current; my space heater & refrigerator have coexisted on the same circuit before.
Tom
Old 03-30-2007, 05:48 PM   #8
balrgn
balrgn's Avatar
Images: 74
Tom
Good clarification, ya beat me to it
Member of VAC
www.balrgn.com
Old 03-30-2007, 05:50 PM   #9
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Thumbs up
I have used oil filled heaters for radiant heat in my RV for years and I like it. No noise, no fuss. It's currently under the table between two barrel chairs. If it is really cold. I open cabinet doors and have a small electric fan I use to get greater circulation. I have never had a overload situation.
I will say that the electrical circuits, both AC and DC, should be a regular preventive maintenance item. Clean, tighten, and clean. Look for indications of overheating. Good grounds are very important for the proper operation of you RV.
Pop Rivet is offline   Reply With Quote
Old 03-30-2007, 06:59 PM   #10
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
the breakers are not the problem it is the outlets.
airstream used a daisy chain type outlet similar in construction to those el cheapo blue splices common in the automotive market.
the idea was to remove the outer covering on the romex then press the seperated wires into the back of the outlet.
when the back cover of the outlet was pressed into place the wires were forced into groves that pierced the insulation and made electrical contact. the contact area ia about 1 millimeter wide.
at any rate it is a sub standard connection that will overheat.
if you plan on running a space heater or any other high load device do yourself a favor and remove the outlet from the wall and take a look see. changing it out to a conventional screw terminal outlet will prevent overheating.
this is a good place for an old lineman's adage. when in doubt change it out!
john
you call them ferrets, i call them weasels.
Old 03-30-2007, 07:12 PM   #11
TomW
TomW's Avatar
Normal , Alabama
Images: 77
When it doubt, CHECK it out
Originally Posted by john hd
the breakers are not the problem it is the outlets... the idea was to remove the outer covering on the romex then press the seperated wires into the back of the outlet. ...
My vintage Airstream did it the right way by looping the wires around the outlet's screws. There is no better connection than that.
I still think breakers are the optimum starting point.
I agree, John, that stripped wires crammed into the back of the outlet is a poor choice for a good connection. But it is expedient. Everything nowadays appears to focus more on getting the job done quickly as opposed to doing the job well.
Does anyone know what year push-in connectors (like John mentioned) were accepted as code?
Tom
Old 03-30-2007, 07:13 PM   #12
Pop Rivet
Pop Rivet's Avatar
Thumbs up
john
Yup!
Old 03-30-2007, 07:35 PM   #13
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Used mine most of the winter
I was full timing right up untill early Feb. I used an oil heater from october on with no problems.
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 03-30-2007, 08:04 PM   #14
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
john
John,
These 'RV outlets' are the industry standard. They are found in every RV I have ever worked on. I hate them......but that's what they use. They are called 'speedwire' outlets and switches. They handle 15 amps on a regular basis but I agree that the concept is one of pure convenience, not safety. In fact, household Romex should not be used in an RV that rumbles down the road as the solid copper wire will eventually work harden from the constant vibration and break. It should be stranded marine cable....but that's another story for another time.
BTW, these outlets should be wired WITHOUT the insulation being stripped from wires. The problems arise when they are stripped first, as the wire alone will not hold properly in the clamp. They are designed for only TWO wires per clamp!!! I have seen some OEMs try to squeeze in 3 by stripping the insulation before assembly, but this method is doomed to failure and I usually find them shorted to ground.....causing all kinds of problems in the coaches.
wacnstac,
I've been using the oil-filled radiators for as long as I can remember. They WILL NOT need the fan blowing behind it, as they set up their own convection currents and will warm the entire trailer. I had 2 in a 40' MoHo and they did the whole thing nicely!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 02:30 PM
Hot water Heater DClark Water Heaters, Filters & Pumps 11 08-26-2002 07:04 PM
Hot Water Heater Replacement rpwx Water Heaters, Filters & Pumps 0 08-25-2002 08:44 AM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 10:15 AM
Other
