Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-15-2017, 08:18 AM   #1
2017 27' Flying Cloud
London , Ontario
Question Can I run the furnace in one zone and the heat pump in the other zone?
Hi all,
I have a 27 FB with 50 amp service and two air conditioner/heat pump units.
When I only have access to 30 amp service, I presume I cannot run both heat pump units simultaneously, so I am wondering if I am able to run the furnace in one zone and the heat pump in the other?
Many thanks for any help with this,
Phil
Philip Jones is offline   Reply With Quote
Old 04-15-2017, 08:23 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
From an electrical standpoint yes. The furnace runs on 12 volts DC while the heat pump is 110 volts AC.
If it is cold outside the furnace would be preferred as it also heats below the floor to protect the tanks.
Not sure where you are camping that would require that much heat but stay warm.
2004 Excursion 4x4
Old 04-15-2017, 03:24 PM   #3
London , Ontario
Thanks for your helpful reply!
Which one is zone 1 and zone 2? Doc Foster Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-23-2017 10:52 PM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Why Does My A/S say one thing on one side and something else on the other Angel73 Title, VIN & Registration 3 05-12-2006 09:46 AM
