Old 03-03-2016, 01:40 PM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Can a New Dometic 15K AC Use the Older Style Air Distribution Box?
I'm always thinking of ways to drop money into my Airstream money pit.
My 2008 has the Dometic 13.5K Penguin II. If I ever needed to replace this unit I would go for the 15k unit.
Would I be able to reuse the existing air distribution box and the wall thermostat with a newer 15K Dometic Penguin II?
The main reason to reuse the ADB is because my interior ceiling has the vinyl and the ADB has left an outline in the vinyl which I don't think the newer style ( I think it came out in 2009) would cover up.
Kelvin
Old 03-03-2016, 03:07 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Kelvin
Shouldn't be a problem, so long as Dometic doesn't change the dimensions of the bottom of the units or the circuitry on their control boards. it happened when they went from their Series I Penguins that used their CCC-I thermostat to the new Penguin II and the CCC-II.
Old 03-03-2016, 03:37 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I think you will need a new control unit. I tried to upgrade my 2008 control unit to one of the new ones and dometic told me it was a no-go, not compatible - 2008 was an analog interface and somewhere around 2010 they went to digital.
wulfraat is offline   Reply With Quote
Old 03-03-2016, 03:57 PM   #4
KJRitchie's Avatar
2008 25' Classic
OK. I can live with a new thermostat. My thermostats little LCD screen is hard to see in the dark. Not really backlit well.
Kelvin
Old 03-03-2016, 06:53 PM   #5
1998 30' Excella 1000
Livingston , Texas
Kelvin
I've read that the thermostat retrofit is not as simple as screwing on another thermostat. You may want to look into it.
Siegmann is offline   Reply With Quote
Old 03-03-2016, 07:23 PM   #6
lewster's Avatar
The OP has a 2008 Airstream, but a newer version (Penguin II) of the A/C unit which already has the upgraded control board and CCC-II thermostat. He is not using the original pieces from 2008 like you have in your trailer.
And yes, I am also a factory authorized Dometic service center……….
Old 03-03-2016, 08:29 PM   #7
wulfraat's Avatar
Gotcha. Bad assumption on my part that he had original equipment from 2008.
Old 03-04-2016, 10:17 AM   #8
KJRitchie's Avatar
2008 25' Classic
I may be wrong with what I have. I have the original AC Dometic 13.5k so maybe it isn't the Penguin II. My Airstream was manufactured in 6/2007
Kelvin
Old 03-04-2016, 10:24 AM   #9
dznf0g's Avatar
Oswego , Illinois
Kelvin
Kelvin, I believe you (and I) have the Penguin 1. Heat pump-A/C. Mine was manufactured in 5/06.
-Rich-
Old 03-04-2016, 10:42 AM   #10
KJRitchie's Avatar
2008 25' Classic
Does the cable run down the wall for the Penguin II contain more wires than the Penguin I? What about the junction box inside the interior air distribution box, does that have to be replaced or does it come with the new AC?
Kelvin
Old 03-04-2016, 10:48 AM   #11
dznf0g's Avatar
Oswego , Illinois
I should let Lewster answer...bit I think you would only need different (more ) cabling to the thermostat IF you had 2 A/Cs (zones). I believe the new CCC2 would just have non-used functionality with the single A/C upgrade.
I also believe the junction box comes with the new A/C.
Wait, do you have Penguin I or II? I though all the Penguin IIs had the non-square bottom cover and CCC2????
-Rich-
Old 03-04-2016, 11:20 AM   #12
lewster's Avatar
Actually, the t/stat wire is identical for both CCC-1 and CCC-II. The problem with adding a second unit is the lack of a communication cable between the original unit (Zone 1) and the additional unit (Zone 2). You will also need a second remote temp. sensor for the new unit.
The original unit becomes the master unit and the new unit is then the slave, but when properly wired, both units operate from a single CCC.
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 03-04-2016, 12:00 PM   #13
KJRitchie's Avatar
2008 25' Classic
Just one AC on my Airstream. Can the square ADB be used on a Penguin II?
Sounds like I'd have to use the rounded ADB.
Kelvin
Old 03-04-2016, 12:38 PM   #14
1990 32' Excella
jonesboro , Arkansas
Get the mod # of the inside unit and call dometic they have been helpfull to me.
joel is offline   Reply With Quote
2013 Dometic Air Distribution Box Removal murreywalker Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-30-2013 03:41 PM
Selling Dometic 15K Penguin yve79 Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-14-2011 08:29 PM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 10:32 AM
Need Dometic Duo Therm Penguin air distribution box gloran Land Yacht/Legacy Motorhomes 1 01-20-2007 11:00 AM
15K BTU Dometic A/C tripping breaker silverback Furnaces, Heaters, Fireplaces & Air Conditioning 48 07-11-2006 09:14 AM
