Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-15-2007, 05:24 PM   #29
danesh
danesh's Avatar
Profile:
Thank you all for letting us to know about the Honda EU2000 and the AC. I saw some treads about Yamaha 2400 which has some surge power build into it. However, right now the most important thing is the Fridge. Let me tell you what i did. I checked the heating element (42 ohms) and no shorts. I checked for the 12 volts DC to the board and it is there (13.2 V). I checked for 120 V AC, and I get that at the heating elements terminals. This is what I suspect. The Board sends the signal to the igniter as if there is no 120 V present, while there is actually 120 V at the terminals. I have not checked the on-off switch yet. Before I order a board I'll try to check that one to make sure I am not spending $200 because of a bad switch. I'll let you all know about this soon.
Also, I think we will go with carrier A/C unless somebody can tell us why we should not.
Thanks and Cheers
Danesh
85 sovereign
danesh is offline   Reply With Quote
Old 06-23-2007, 04:58 PM   #30
bilby05
bilby05's Avatar
Profile:  1969 31' Sovereign
Canyon , Texas
Service Manual
You need to get a 74 "service manual."
That will give you the basic instructions. It will be the best investment you ever made.
Once you have it, then it becomes very easy to guide you from there.
What model Carrier AC did you buy?
Hey Andy,
You are indeed a wealth of information. Along the line of sevice manuals: I know they did not make a service manual for my '69 Sovereign, but have been told that the later ones (74?) offer a wealth of information. Is it worth it to buy the later one to apply to working on an earlier one? BTW the axles are working fine now(after your folks straighened out my "installer.") That was a close call.
thanks, bill b.
bill b.
1969 Airstream Sovereign 31'
2001 F250 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 06-23-2007, 06:57 PM   #31
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Here's a link to an Ebay auction for a reproduction 1972 service manual:
eBay Motors: 1972 Airstream Factory Service Manual (item 260130655692 end time Jun-27-07 07:22:39 PDT)
It is buy it now for $49.99
Old 06-25-2007, 11:00 AM   #32
Commercial Vendor
Profile:  Corona , California
Originally Posted by bilby05
Hey Andy,
thanks, bill b.
Buying a service manual, even though it is not for your year trailer, is the "best" investment you could ever make.
If it answered just one question, then it already paid for itself.
The manuals cover many things that are not year essentail, such as how do you work on the brakes, sheet metal, etc.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 07-23-2007, 11:46 PM   #33
SnorkyII
SnorkyII's Avatar
Profile:  2008 22' Safari
Escondido , California
Armstrong A/C Replacement with DUOTHERM DOMETIC RV AIR CONDITIONER 13.5 BTU
Andy, are you there?
I am replacing the Armstrong A/C on my 73 Argosy with a DuoTherm Dometic 13.5 BTU unit. The question is, do I use the roof mounting from the Armstrong, or do I need a special part (ie drip pan?) from Airstream?
Sam Halderman
PS: The new A/C has not arrived yet, and I haven't seen the installation instructions.
Snorky II
Escondido, CA
WBCCI #2055, VAC
Charter Member FCU, WBCCI Unit #004
ESCAPEES SKP 58345
AIR #13642
08 Safari Sport 22, 03 Toyota Tundra
73 Argosy 22
SnorkyII is offline   Reply With Quote
Old 07-24-2007, 05:10 AM   #34
Commercial Vendor
Sam Halderman
You will need a drip pan.
Inlandrv.com
800-8777311
Old 07-24-2007, 05:16 AM   #35
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Sam Halderman
Sam,
Dometic has a new fitting kit that eliminates the need for the drip pan and still allows you to connect the A/C drain to your internal drain hose. It will make for a cleaner installation without the drip pan.
I'm traveling at the moment and don't have the part #, but you can call Dometic Direct at 1-800-366-3842, tell them that you need the drip kit that replaces the old drip pan for an Airstream and you should be good to go. About $50 IIRC .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 07-24-2007, 07:16 AM   #36
SnorkyII
SnorkyII's Avatar
Lew & Andy: Thanks for the information about the Dometic kit. I will call Dometic after the new A/C arrives.
Sam
Snorky II
Escondido, CA
WBCCI #2055, VAC
ESCAPEES SKP 58345
AIR #13642
73 Argosy 22
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-09-2005 03:53 PM
Solar Panel Installation 69Overlander Generators & Solar Power 23 11-19-2002 10:25 AM
Camping World - No A/C Pan? 1985air345 Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-25-2002 09:55 AM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 09:29 AM
test
