Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-19-2006, 06:17 AM   #1
PhilMateo
Profile:  1965 26' Overlander
Acworth , Georgia
A/C Compressor question
Folks,
I've searched all posts, and don't see this question addresses yet, so here goes...
In my '65 Overlander with original Armstrong Bay Breeze a/c, the compressor seems to trip off after an hour or so of hard work. We get cool air during that time.
I am assuming the compressor is over heating, and the thermal switch is cutting unit off.
Is this assumption correct, and what does that tell me about what I need to fix?
PhilMateo is offline   Reply With Quote
Old 05-19-2006, 07:23 AM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Hi Phil,
If your compressor is overheating as you say, then you either have a comp. going bad or there is a blockage somewhere in the refrigerant line, condenser, evaporator or capillary tubes that is causing a restriction that will overheat the compressor and causing the shut-down due to lack of refrigerant entering the unit. If you have an AC amp clamp, you can do a running amp test on the compressor to check how much amperage it is drawing and compare it with the data plate. Otherwise, it sounds like you need a qualified A/C tech to look at it to verify if there is a blockage or not.
One other problem might be the run capacitor, but I have never seen one shut down a comp. after an hour. They usually act up right away.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 06:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
